sleepsherpa
Can a Body Pillow Improve Sleep?
For the longest time, we have depended on the mattress to solve most of our sleep problems. But even the most expensive mattress begins to sink and gets dips within the first five years. The more the mattress sags, the lower is the support provided to the body. No matter what kind of mattress you buy, you cannot keep it from sagging. Sooner or later, it is going to dip and sag, leaving you with an improper sleep position.
This is one of the reasons why several people change their mattress so often. A sagging mattress has little firmness and fails to provide your body with the support it needs for proper proper sleep. When you keep sleeping on this worn-out mattress, you develop soreness and aches and pains in various parts of your body. You believe that you are suffering from some ailment when the actual culprit is your mattress.
Unfortunately, mattresses will sag. There’s not much to do about it. But instead of relying only on a mattress for proper sleep, why not choose another solution for quality rest? That’s right; we are talking about a body pillow. It is the next best alternative to a mattress for adding in a good night’s sleep. Whether you suffer from medical conditions that make it hard for you to sleep at night or sleep on a mattress that does not provide enough support, a body pillow can make sleeping a more comfortable and relaxing experience.
What Is A Body Pillow?
A pillow that’s narrow and long and runs the entire length of the body is called a body pillow. Initially, body pillows were mostly used by pregnant women for extra support during sleep. But these pillows have gained massive popularity in recent years because they provide support to the whole body when the mattress fails to do so.
A lot of people prefer to sleep with a cuddle pillow. But these pillows are usually small and do not provide support to the entire body. A body pillow is soft and comfortable but firm enough to support the top leg (for side sleepers), torso, back, and arms throughout the night. Body pillows are counted among the best orthopedic pillows and are widely available online, at bedding stores, and
What Is Body Pillows Made Of?
A body pillow is no different than a regular pillow and can be made of a variety of materials. Some of the materials that a body pillow is made of are:
Shredded latex: Body pillows with an outer cotton casing and a shredded latex fill are bouncy and conform to the shape of your body. Shredded latex body pillows are great for those who suffer from neck and shoulder pain because it’s responsive and keeps the spine aligned while hugging the body. Natural latex is hypoallergenic and can be conveniently used by those with allergies.
Memory Foam: Body pillows are also made with memory foam, another hypoallergenic material. Memory foam is breathable and comfortable and also regulates temperature. The firmness of the pillow can also be adjusted according to preference.
Wool: If you want a body pillow that keeps you cool in summer and warm in winter, then choose wool. Because wool is a natural insulator, it keeps you comfortable in all seasons. Wool body pillows are comfortable to sleep with, and also keep the back and spine aligned, regardless of your sleep position.
Feather/Down: Although body pillows made of feather or down are soft, they aren’t capable of providing the best support. Besides, feather or down can cause allergies, which doesn’t make them suitable for all.
Wool-Latex Blend: When wool and latex are combined to make a body pillow, it becomes soft and supportive at the same time. The combination of shredded latex and wool gives the pillow a firmer feel, while the wool functions like a natural insulator and promotes breath-ability and circulation. The latex makes the pillow responsive while keeping your spine aligned and helping relieve pressure points.
Kapok: Cotton makes for some of the most breathable and comfortable body pillows. Kapok cotton is used to make organic body pillows, which have the same fluffiness of down without the feathers. Cotton pillows keep you cool on hot nights, providing proper support for side sleepers, spine alignment, and pressure relief.
Benefits of A Body Pillow
Pillows are used by everyone for comfort. But pillows are also great at providing support to the body. These days, there are orthopedic pillows, which are ergonomically designed to provide support to various parts of the body. There are pillows for the legs, for the back and spine, and for the neck and shoulders. Body pillows combine the support of all pillows into one. If you have a body pillow, you can use it for supporting any part of the body or the entire body.
Some benefits of the body pillow are:
Spinal Alignment: Keeping the spine aligned is of utmost importance when sleeping. When we sleep, we often aren’t aware of our position. This leads to soreness when we wake up. A body pillow keeps the sleeper supported no matter which position he sleeps in, improving spinal alignment and keeping aches and pains away.
Pressure Relief: When we are in a supine position, our body takes the maximum pressure. This is heightened if the mattress isn’t supportive enough. A body pillow provides extra support, relieving the pressure and preventing soreness.
Improved Circulation: When your sleep position isn’t proper, your blood circulation is also poor. A body pillow keeps you supported and comfortable, keeping your sleeping position right and improving circulation.
Diminished Snoring: A body pillow can be used to elevate the upper part of the body, to help with snoring and sleep apnea. Body pillows designed for sleep apnea makes sure that the sleeper remains in a side sleeping position all through the night, helping relieve symptoms of sleep apnea like obstructed breathing, snoring, coughing, and dry mouth.
Body pillows are available at all bedding stores or online marketplaces. Quality body pillows last long and provide ample support for the whole body.
