Nadywen
Advice on eliminating mold.
I am a builder and at the moment I am engaged in a construction project in a very rainy area.Our team laid the foundation and built the walls and roof, but due to the fact that the room is not heated because the appropriate communications have not yet been laid,we were faced with the appearance of mold and we had no experience with eliminating this problem before.Maybe someone has some advice about the solution of this problem?
Dude, when have you first mentioned mold at your construction site?! Mold is a rather serious problem, and in case it appears during the construction process, it means that the residents will be facing constant problems with it, and that is really really bad actually. I would recommend you to call for the services of a specialist, and see what he can do. After that, you could also read this https://ratslab.com/crawl-space-encapsulation-complete-guide/ it is a crawl space encapsulation guide, this thing actually helps you avoid mold, it is probably one of the most efficient ways of preventing it.
