Aircon Quotes (From Aron)
I learnt from 2 air-con specialists that the brands we should avoid are LG (veri expensive on spare parts), Mit heavy Industries (Made in China and poor quality), Fujitsu (poor quality). Highly recommended brands are Mit. Electric, Panasonic, Tobshiba and Daikin. Hope this piece of advice will help you to decide which brands to consider. Never believe in salesman cos they will never tell you the truth. You have to do your homework.
  • Replies 2.1k
  • Views 657.4k
  • I was told my a saleman selling aircon that the default grey insulation is good enuff if your aircon trunking is expose as most of the HDB are. And not hidden as those in the condominium. Armaflex ar
  • ok, there are retailers who try to cut corners to save $$. eg. they offer you system 3 at (est) $3.4k, generally the air-con mfgr specs will specify wat type of material to use, eg. for insulation, pi
  • i got a quote from gain city. Mitsubishi invertor, compressor is 30k btu, then 3X 9k units for 3 rooms, and a 22k unit for the living area. Cost is $3.4k. is it cheap? TO be honest, im a noob when it
FYI
toshiba--- the motor in the outdoor unit, condenser is made in japan, rest of it unsure, the indoor units are not made in japan
inverter 13K+22k btu-$30001/2 armmaflex, 22swg copper pipe, 16mm drainage pipes
daikin 9000 btu inverter--- $1100, 1/2 armmaflex, 22swg copper pipe, 16mm drainage pipes
2 times install
Edited by fini
dear all,
im looking to get a single split unit to put in my living room only.
the space there is abt 35 sqm.
cant seem to find any info/pricing on single splits aside from that known aircon blog.
need latest recommendation / pricing for single split unit (18btu to 24btu ok?).
your inputs are much appreciated. :D
Hi All
I am using a Sys 4 Mitsubishi Elect Starmex for my new place. By Nation Cool. I would like to highlight that please Do not use Nation Cool. Experience only pleasant up to paying deposit. The guy self assumed and put our air con right smack in the living room, hanging low like a TV. Refuse to change the positioning, want us to pay extra to change the location and gave a loud outburst.
In the first place he did not meet us and indicate clearly where he would place the aircon. He just arrived with no prior notice and started installations. Very upset at the service. Trunking not straight also. It's wavy slanting kind of trunking
Do not use them!
Hi All
Do not use them!
thanks for the info!
GainCity quoted me about 1169 for the Mitsubishi (MEC) (non-inverter) MUAD18VA/MSA18VA (18k BTU) single split. AllBest quoted me about 50 bucks less. Bracket (+150) and isolator (+280) are separate charges. Toshiba is about 1299. Didn't ask about the insulation/copper piping and whether it's a two-times installation though.
dear all,
Just got my Samsung 18k BTU installed at $1028. Bracket $100. Isolator $250. Purchased and installed by Geocool. I job well done!
What brands have sys 3, non inverter with 3 ticks?
I know Toshiba is one of them
Alot people buying from GainCity.. are they good in installation & service?
is CoolServe is good?
i will be getting quotes from GC these few days for ME StarMex Sys 4.
but confused about inverter vs non-inverter.
I on aircon only 1 x room but everynight. inverter or non-inverter??
If you only turn on 1 air-con everynight get non-inverter. Not worth getting inverter as in order to save electricity u will need to turn on 3 or more units.
Yday, I went to Living Tomorrow 2010 fair at EXPO. I went to 3 air-con shop to ask for quotes.
Air-con Brand: ME StarMex Sys 4 Inventer (For 4 bedrooms)
1) Creation air Pte Ltd
Price: $3299
Salesperson Name: Mike
Workmanship Warranty: 8 years
Insulation type:Thermalflex Class 0
Stainless Steel Bracket for old HDB :$100
Extended Warranty 5 years: $350
Comments:The salesman claim that 1/2 armaflex is make in china and is no durable as compare to Thermalflex that is make in Thailand . No worries , as they are giving 8 years warranty for the workmanship.
2) All Best
Price: $3450
Salesperson Name: Gary
Workmanship Warranty: 5 years
Insulation type: 1/2 armaflex
Stainless Steel Bracket for old HDB :$120
Extended Warranty 5 years: $300
Comments:The salesman claim that 1/2 armaflex is durable and last longer as compare to 3/8 since it thicker.
3) BestTech
Price: $3349
Salesperson Name: Jack
Insulation type: K-flex
Comments:The salesman claim that 1/2 armaflex is make in china and is no durable as compare to K-flex as it made in Italy
Do let me know the quote you get from GainCity ?
Hi all,
just went to GC at IMM, was recommended LG system 3 with ionizer function (my hubby and I got allergic rhinitis) and was quoted $2629 including installation. Does anyway have experience with LG health+ series? Thanks for ur help.
Ironwoman
went to GC cwp. got the following quote (nett $)
starmex sys 4 inverter MXY-4A28VA = $3600 (No Stock Till mid-end Jan)
non-inverter one = $2800
- 1 yr equipment warranty
- 3 yr worksmanship warranty (parts, labour, transport)
optional upgrade to class 0 (1/2 inch armaflex insulation + grade 22 copper pipe) = $230
optional 4 yrs worksmanship warranty = $439
starmex inverter one has 2 x compressor, so if i one aircon everynight for 1 x room, only use 1 x compressor.
total damage (if take up all optional) = $4270
Forgot to check exactly what is worksmanship warranty?? Anyone knows?
E.g. If my compressor spoilt or liquid pipe leaking, they cover everything?
E.g. If I ask them for normal servicing, need to pay?
Cos not sure whether is it worth to get the additional worksmanship warranty.
Thanks!
Price: $3299
2) All Best
Price: $3450
3) BestTech
Price: $3349
btw 3101, the quotes you got at the expo fair is so much better!!
cheaper price and minimum 5 yrs worksmanship.
extended warranty of 5 yrs also cheaper!
i think GC over priced... any comments anyone?
I think if you do a search in the forum for the above companies from EXPO, you will find some comments about them...after that then you decide if you still want to go for them. As for GC, it will be fair if you compare them with Courts, HN, Best or CarreFour....Good Luck....
Hi
Got a quote from BEST TECH. MITSUBISHI INVERTER MULTI system 3
MXY-3A28VA $2700 with freebies.....
Sounds reasonable ? Any comments to share pls
