Jame
Hdb Bto 4 Room
Hi all
Any 1 can tell me what is pre pack cement ?
Is it must use that for my BTO flat ?
Is it very expensive?
Please help
Thanks all
Jame: there are a few variations to the additional cost but basic point across will be cost of tiling the home will go up if tiles are your choice. By how much will then depend on if you use contractors or designers as each will have to earn their keep for their biz.
Alternatives then would be Vinyl tiles which is simply overlaying over the cement screed or laminate so play around with these. Perhaps tiles for main areas where cleaning requires heavy mopping and Vinyl or laminate in bedrooms where light mopping will suffice.
Just some 2 cents worth....
Hi double em
Ya why never think of that , can lower my cost .
Thanks
welcome as long as you can accept alternative floorings then why not?
Vinyl flooring will be harder and little more resistant to water and will not have the hollow sounds over years compared to laminate.
Laminate will be good for budget but resistance towards water is less than vinyl and of course tiles.
For exactly which is cheaper I cannot comment paiseh as we went for vinyl instead of laminate this time.
Hi doubleEM
For vinyl and laminate what the price different ? Is it a big gap ?
Thanks
Sorry for late reply. Not too sure but I guess costing wise would go like this:
Most Expensive - Tiles
Middle - Vinyl
Lowest Cost - Laminate
So this is what I've experience and how I feel so it now depends on what you are looking for. Hope this helps.
Hi all
For bto flooring , tile $3.2 psf include pre pack cement , laying , everything $9 psf is it expensive?
Thanks
Hi all
Thanks
market rate.
Quote
Hi Freakerz
Will try can get a bit cheaper from this contractor.
Thanks
