will0
4rm New Standard Flat Quotation
Hi, this is my quotation.
Will appreciate if members here can help to advise on the pricing and will value any feedback.
thanks,
_________________________________________________________________________________________
1.00 DESIGN SERVICES
1.01 Interior design & space planning with furniture layout plan FOC
1.02 Perspective drawings, materials & colours proposal FOC
1.03 Site co-ordination to oversee the renovation FOC
1.04 Application of HDB renovation permit FOC
1.05 Arrangement for PUB gas pipe installation & connection FOC
2.00 GENERAL WORKS
2.01 Chemical cleaning upon completion of renovation works $ 1 50.00
2.02 Protection of new flooring with corrugated paper $ 1 50.00
3.00 MASONRY & FLOORING WORKS
3.01 Supply & lay 600mm X 600mm China polished homogeneous floor tiles ****/dining hall &
household shelter c/w Teakwood timber skirting $ 1 ,950.00
3.02 Supply & lay laminate flooring at 3 nos bedrooms c/w Teakwood timber skirting (Supreme, cement
screeding will be done by HDB contractor) $ 2 ,385.00
3.03 Supply & construct 50mm kitchen cabinet, fridge & washing machine cement mortar base c/w
matching tile finish $ 3 00.00
4.00 PAINTING WORKS
4.01 Supply & apply ICI Pentalite or Nippon Super Vinilex 5000 emulsion paint to whole house internal
walls & ceilings (unlimited colour choice, oil paint for all exposed pipes & door frame if necessary)
$ 1 ,050.00
5.00 CARPENTRY WORKS
5.01 Design & fabricate U-shape kitchen cabinet c/w high-pressure laminate, ABS trimming, designer
handles, a chest of drawers, a pair of glass doors, stainless steel dish rack & cutlery tray (22ft
total length) $ 2 ,250.00
5.02 Supply & install solid surface worktop at kitchen cabinet c/w backsplash (13ft length) $ 9 75.00
5.03 Design & fabricate L-shape full height wardrobe at main bedroom c/w aluminium framed sliding
frosted glass door (9ft length) $ 2 ,250.00
5.04 Design & fabricate half height feature wall for LCD TV **** hall c/w high-pressure laminate
finish (7ft length) $ 9 80.00
5.05 Design & fabricate suspended TV console **** hall c/w high-pressure laminate finish (7ft length)
$ 7 70.00
5.06 Design & fabricate feature wall cum shoe cabinet at entrance of household shelter c/w highpressure
laminate finish (6.5ft length) $ 1 ,430.00
5.07 Design & fabricate wooden plank at window ledge of main bedroom c/w high-pressure laminate
finish (L-shape, 10ft length) $ 4 00.00
5.08 Design & fabricate wooden plank at window ledge of bedroom 2 c/w high-pressure laminate
finish (9ft length) $ 3 60.00
5.09 Design & fabricate wooden plank at window ledge of bedroom 3 c/w high-pressure laminate
finish (9.5ft length) $ 3 80.00
6.00 PLUMBING WORKS
6.01 Supply labour to run extension copper piping for kitchen sink $ 8 0.00
6.02 Supply labour for installation of kitchen sink including tap & drainage piping $ 8 0.00
6.03 Supply labour for installation of storage heater at common toilet $ 9 0.00
7.00 FITMENT WORKS
7.01 Supply & install 10mm clear tempered glass shower screen at main toilet c/w swing door
(5.5ft length) $ 5 00.00
7.02 Supply & install aluminium sliding windows with 3-way track at service yard c/w natural anodized
frames & normal tinted glass pane (casement window at one side only) $ 7 50.00
7.03 Supply & install aluminium sliding window grilles **** hall & 3 nos bedrooms c/w anodized
finish & normal square design (upper portion for full window) $ 9 80.00
7.04 Supply & install top-tracked aluminium sliding door (2-panel) at kitchen entrance c/w white powder
coated frame & clear glass panel $ 6 20.00
8.00 AIR-CON WORKS
8.01 Supply & install Mitsubishi Starmax Inverter system 4 air-conditioner ****/dining hall & 3 nos
bedrooms (22,000 BTU & 9,000 BTU X 3 respectively) $ 3 ,900.00
9.00 FIBROUS WORKS
9.01 Supply & install false ceiling at dining hall & foyer $ 2 80.00
9.02 Supply & install L-box cornice **** hall $ 4 20.00
10.00 ELECTRICAL WORKS
10.01 Supply labour for installation of 22 nos light fittings for whole house $ 2 20.00
10.02 Supply & install 9 nos new lighting points for living/dining hall $ 3 15.00
TOTAL AMOUNT ………………………………………………………………………………………………… $ 2 4,015.00
NOTES:
a The above quotation is subject to revision upon confirmation of dimensions & materials
b Polished homogeneous floor tiles for living/dining hall & household shelter are base on $2.50 psf
c Haulage & any fees payable to the relevant authorities shall be billed separately base
on the amount charged
Hi may i know who is ur ID?
Hi I have PM you the reply.
Feel free to let me know your comments as I wanna make a comparison and hear all views. Thanks
thanks,
2.00 GENERAL WORKS
2.01 Chemical cleaning upon completion of renovation works $ 1 50.00In Package
2.02 Protection of new flooring with corrugated paper $ 1 50.00In Package
Mine is 600mmX600mm for living,dining,bedrm2 & bedrm3 and MBR laminate included in package with topup $1100
matching tile finish $ 3 00.00mine included in package
4.00 PAINTING WORKS
$ 1 ,050.00mine 6 colour max included in package
total length) $ 2 ,250.00mine total 29ft topup $1045
5.02 Supply & install solid surface worktop at kitchen cabinet c/w backsplash (13ft length) $975.00Mine granite top, length 14ft topup $680
frosted glass door (9ft length) $ 2 ,250.00same L-shape 8ft=$1560
$ 7 70.00
laminate finish (6.5ft length) $ 1 ,430.00mine $1080
finish (L-shape, 10ft length) $ 4 00.00Didn't do
finish (9ft length) $ 3 60.00Didn't do
finish (9.5ft length) $ 3 80.00Didn't do
6.00 PLUMBING WORKS
6.01 Supply labour to run extension copper piping for kitchen sink $ 8 0.00in package
6.02 Supply labour for installation of kitchen sink including tap & drainage piping $ 8 0.00in package
6.03 Supply labour for installation of storage heater at common toilet $ 9 0.00in package
7.00 FITMENT WORKS
(5.5ft length) $ 5 00.00$450
frames & normal tinted glass pane (casement window at one side only) $ 750.00Mine $680
finish & normal square design (upper portion for full window) $ 9 80.00mine $1424
coated frame & clear glass panel $ 6 20.00Didn't do
8.00 AIR-CON WORKS
bedrooms (22,000 BTU & 9,000 BTU X 3 respectively) $ 3 ,900.00Didn't do
9.00 FIBROUS WORKS
9.01 Supply & install false ceiling at dining hall & foyer $ 2 80.00in package
9.02 Supply & install L-box cornice **** hall $ 4 20.00in package
NOTES:
Overall your quote is about the same as mine except for some item, maybe the measurement also abit difference that why the quote also difference.
My total is $20850(+ as tiles chosen is more exp than given)
Hi Moderators, Please kindly close this thread as I have confirmed my renovation with another ID firm. Price is slightly higher but the service and response time is much better (keeping my fingers crossed :) ).
Thanks.
