Comparison On Quotation From Two Different Id
Hi all,
Received quotations from 2 different Ids. Would like to ask for your advise.
Id A
Hack off existing 3 bedrooms homogenous floor tiles = $ 400
Supply sand and haulage material to door step = $ 350
Clear debris off site = $ 150
Chemical washing whole unit (2 times) = $ 120
Apply 3 bedrooms cement screeding = $ 600
Construct master toilet cement screed = $ 90
Supply and lay 3 bedrooms parquet w/ skirting and varnishing = $ 2700
Labour fee to install master toilet WC bowl = $ 100
Labour fee to install master toilet vanity in/out piping = $ 80
Labour fee to install 2 toilet spray tap = $ 60
Fabricate and install 2 toilets top track alum bifold door = $ 520
Fabricate and install master toilet 10mm tampered glass shower screen = $ 400
Fabricate and install 9ft full height laminate feature wall for bomb shelter = $ 1710
Fabricate and install master toilet top and bottom laminate vanity cabinet = $ 1050
Supply and install master toilet vanity solid surface worktop = $ 350
Supply and install master toilet vanity length mirror = $ 240
SUBTOTAL Id A $ 8920
Id B
Supply labour & tools to hack off existing floor tiles w/ skirting at 3 nos bedroom area = $ 300
Supply labour & building materials to level 3 nos bedroom flooring with cement screed. = $ 400
Supply & install WPC colour aluminium acrylic bi-fold doors at 2 nos of toilets = $ 320
Supply & install a frameless shower screen enclosure at Main bedroom toilet = $ 680
Supply & install teak strip / parquet w/ lacquer to 3 nos bedroom floor = $2200
Supply labour & material to install timber skirting w/ lacquer to 3 nos bedrooms = $ 400
Supply & install 1 nos of coloured pedestal toilet bowls at Main bedroom & Common toilet = $ 250
Supply & install 2 nos handspray set at Main bedroom & Common toilet = $ 80
Supply & install a selected brand solid surface 5ft vanity top to Main bedroom w/o wash basin. = $ 400
Supply & install a full length mirror w/ suspended cabinet = $ 800
To fabricate 9ft full height design wall feature using solid plywood & high pressure laminate = $1260
SUBTOTAL Id B $7090
Any advise on the pricing? Are both reasonable price?
As you can see Id B's price is much cheaper compare to Id A's for the same work they do.
My concern is: Id B's work will be less excellent compared to Id A's because it is less renowned company.
Thanks in advance
Hi all,
Id A
Hack off existing 3 bedrooms homogenous floor tiles = $ 400 OK
Supply sand and haulage material to door step = $ 350 ok
Clear debris off site = $ 150 ok
Chemical washing whole unit (2 times) = $ 120 ok
Apply 3 bedrooms cement screeding = $ 600 ($500)
Construct master toilet cement screed = $ 90 What is this?
Supply and lay 3 bedrooms parquet w/ skirting and varnishing = $ 2700 $2200
Labour fee to install master toilet WC bowl = $ 100 $80
Labour fee to install master toilet vanity in/out piping = $ 80 With item below $80
Fabricate and install 2 toilets top track alum bifold door = $ 520 $360
Fabricate and install master toilet 10mm tampered glass shower screen = $ 400 Quite cheap
Fabricate and install 9ft full height laminate feature wall for bomb shelter = $ 1710 Quite ok Try $1600
Fabricate and install master toilet top and bottom laminate vanity cabinet = $ 1050 $750
Supply and install master toilet vanity solid surface worktop = $ 350 Quite ok Granite also around same price
Supply and install master toilet vanity length mirror = $ 240 OK
Id B
Supply labour & tools to hack off existing floor tiles w/ skirting at 3 nos bedroom area = $ 300 Cheap
Supply labour & building materials to level 3 nos bedroom flooring with cement screed. = $ 400 Cheap
Supply & install WPC colour aluminium acrylic bi-fold doors at 2 nos of toilets = $ 320 Cheap
Supply & install a frameless shower screen enclosure at Main bedroom toilet = $ 680 Exp
Supply & install teak strip / parquet w/ lacquer to 3 nos bedroom floor = $2200 OK but they should be using vanish and not lacquer
Supply labour & material to install timber skirting w/ lacquer to 3 nos bedrooms = $ 400 Should be inclusive in Parquet
Supply & install 1 nos of coloured pedestal toilet bowls at Main bedroom & Common toilet = $ 250 Cheap
Supply & install 2 nos handspray set at Main bedroom & Common toilet = $ 80 OK
Supply & install a selected brand solid surface 5ft vanity top to Main bedroom w/o wash basin. = $ 400 $350
Supply & install a full length mirror w/ suspended cabinet = $ 800 Quite OK but note that not inclusive of Top Cabinet
To fabricate 9ft full height design wall feature using solid plywood & high pressure laminate = $1260 Cheap but goto see their design
SUBTOTAL Id B $7090
Any advise on the pricing? Are both reasonable price? See above
As you can see Id B's price is much cheaper compare to Id A's for the same work they do. Please check their details for material and any hidden cost
My concern is: Id B's work will be less excellent compared to Id A's because it is less renowned company. You mean you prefer branded one? Need to see their workmanship and references first. Also their attitude and services counts
Thanks in advance
Edited by bullet
Thanks for your comments Bullet....
Others.. care to share your opinion.
We haven't met ID B personally. He said it's still too far from getting the key.
But ID A offer to meet us. He even told us if confirm no need deposit as it's only small amount for him. But when it's started we need to pay 20%. We're so impressed by his sincerity. But again price on the high side.
I can feel that he is sincere too. Usually, once confirm, most ID will ask for $$$ first even for small amount. If you feel that the price is high, just look for more quote before confirming since you have the time. See more so that you have a good feel of the quote and understand if there is any hidden cost. Attitude and service is important. The price is not able to tell you much about the service and attitude. Only through communicating with them, before you feel the chemistry
