softballer
Meng Design, City Design And Stiles?
bumping this thread.
Any recent customers from Stiles? The old thread was locked.
So far, among the 3 IDs that i am comparing, Stiles is offering the best package but i am afraid that we might over-look some hidden costs and didn't factor it.
in the mid of getting an ID, wondering if anyone has any prior experience with Meng Design, Stiles or City Design?
Help needed...
Hey softballer,
so how's reno? Done?
i had got a quotation frm Meng b4. i find dat e person i spoke 2, understand my needs & requirements. Sticked closely 2 wat i wan & gave a proposal dat is innovative & pratical. Somemore, it works out 2b below my budget. :rolleyes:
Hey softballer,
i had got a quotation frm Meng b4. i find dat e person i spoke 2, understand my needs & requirements. Sticked closely 2 wat i wan & gave a proposal dat is innovative & pratical. Somemore, it works out 2b below my budget. !!
neh... just got my keys this month.. not really in a rush to get ID..
still sourcing for the best quotation with best worksmanship.. like a gamble.. lolx
how much is ur quote? care to share? pm me if necessary
Hey softballer,
Hey jaCKY,
did you eventually engage Meng (it is Meng Design and Build, right?) for your reno? heard from a colleague that his sis had engaged them and were very satisfied with the workmanship. i intend to suss them out but after 3 months of ID-searching, a bit tired liao... maybe start after CNY la ..
mind sharing the quote u received? :dunno:
Hey softballer & aTi,
by popular request, i'v type e quotation out.
Its kinda preliminary & its dated back to 5mths ago.
Mine is a new 4rm standard flat, cums with kit floor & wall tiles, bathroom floor & wall tiles, concealed wiring & piping.
Not in e quote:
- inlet & outlet pipings.
- lighting pts.
- installation of accessaries/fittings if any.
Item 10 - becos of e slightly odd bedroom shape,
- to make e 2 bedrooms more equal in size;
- master bedroom shift door position;
- gota hack e affected walls & make good;
- install 3 new door frame;
- use back e existing veneer door.
For your reference:
All works are quoted inclusive of labour, materials & equipment necessary for an acceptable finish.
MASONRY WORKS / WET WORKS
To supply labour & materials to construct & lay the followings:
1) Supply & lay 600 x 600 Homogeneous flooring @ Living, Dining, Shelter & 3 Bedrooms c/w skirting. $4600
2) Construct kitchen cabinet cement base c/w side tile finishing. $380
CARPENTRY WORKS
3) Design & fabricate sliding wardrobe with laminate finish & ABS trimming @ master bedroom: $2100
*Size : L 2100mm x D 600mm
*White Polycam as internal finishing.
*1 pc of full mirror.
*Perspective drawing provided.
4) Design & fabricate sliding wardrobe with laminate finish & ABS trimming @ bedroom 2: $1500
*Size : L 1500mm x D 600mm
5) Design & fabricate sliding wardrobe with laminate finish & ABS trimming @ bedroom 3: $1800
*Size : L 1800mm x D 600mm
6) Design & fabricate top & bottom kitchen cabinet with laminate finish c/w ABS trimming for door panels: $3200
inclusive of:
*Size : L 32 ft
*Stainless Steel dish tray.
*Designer handle.
OTHERS
7) Supply labour & material to install solid surface top for kitchen worktop: $1120
*Size : L 4200mm
*Inclusive of cutting sink & stove size.
*Inclusive of Original Side Skirting.
8) Supply & install sliding window alum grilles @ whole unit. $1000
9) Painting for whole unit wall & ceiling. (ICI / NIPPON) $800
10) To hack the 3 bedroom wall & install new bedroom door frame. $1500
Total $18000
For me, i don't realli like Meng (Tampines branch).....
They are so called the branded good such as LV in renovation industries as mentioned by the ID there...The attitude is not tat good coz we need a rough quote. They asked whether have we get the key and when we reply no....ha ha..they say that then it is better to come another day... :sport-smiley-004:
ANyway, it is up to one to decide.....hee hee
Hope you can find a good ID ...Cheers!:dancingqueen:! !!
