Bedok Central
  • Replies 3.9k
  • Views 677.4k
  • Regarding quotations.... As mine is low budget (unlike some of you) was looking for ID's and comparing cost.... Just wanted basic's reno only... done first... so i came up with a need list of rennov
  • frederick_chia
    frederick_chia
    Jovi dropped by this afternoon & confirmed no pipe leakage in my unit. However, she also cannot give a confirmed explanation on the damp walls. What's worse, some walls are turning moldy liao. Can
what ever the model as long as it flush off the thingys =P
kepler
Yours should be this 2pc model 9707.
Correct?
-------9708 --------------------------&------------------9707--------------&---------------WO109S--------------
Edited by big orange
i spray insecticide leh....the ants keep cumingto the livingroom via the corridoor area..cant tahan...cos the tiles is milky white,so wheneveri see black things crawling n moving...i will step them to die..hahah..then i put the erm, is is call the moth ball, outside mi door then spray insecticide n they stop coming...
Correct?
yep..looks like 9707
imho it isnt that good but I am hoping to raise the water volume to see if it can 1 flush clear everything 95 percent of the time..right now its like 1 flush can clear everything 75 per cent of the time...
so its like using more water to save water...haiz
Edited by kenlew8
did you make a feedback then? i think it important to make a feedback to them. To let them know the gap between their promise and your expectation.
need to track the headquarter and their destination. if both are outside your house, use the "white chalk" which can be bought like 80cent, to draw a boundary around the entrance, they they unable to come through.
I alway feel itchy all over body when see army of ants roaming pass ....
kenlew8
Flush problem
The flush thingy beside the blue float, the tube pcs can be adjusted by twising, it will increase the water level also. but you will have to make sure the tube at the bottom has to be covered so that water will not be drain off. to increase the water level. I found out this by chance.
hope you understand. wat i meant
big orange
Ant Problem
Are they attracted to something? maybe you can check around.
:rolleyes:
Double Rainbow @ Linear Green
Edited by herbman76
This will be how it look like in LG toilet.
9708
109S
