Bedok Central
anyone knows the future Open-net how will it enters our house?
  • Replies 3.9k
  • Views 680.2k
  • Regarding quotations.... As mine is low budget (unlike some of you) was looking for ID's and comparing cost.... Just wanted basic's reno only... done first... so i came up with a need list of rennov
  • frederick_chia
    frederick_chia
    Jovi dropped by this afternoon & confirmed no pipe leakage in my unit. However, she also cannot give a confirmed explanation on the damp walls. What's worse, some walls are turning moldy liao. Can
2012 - 2013
I don't wanna wait till then, then think of how it enters the house.
our estate is only set for 2012, installation 1st time is free, but if you reject and wants it next time, it will be $220 for first 15M trunking and sub 5M $33.
trunking will be from outside DP box into your house so drilling is a must and it is recommended to install the fiber box near to tv point.
be prepared to have lotsa power points near it too.
kenlew8
Flush problem
The flush thingy beside the blue float, the tube pcs can be adjusted by twising, it will increase the water level also. but you will have to make sure the tube at the bottom has to be covered so that water will not be drain off. to increase the water level. I found out this by chance.
hope you understand. wat i meant
big orange
Hi Big Orange and Herbman,
HDB finally got the main con to call the subcon who came by yesterday to fix and teach me how to change the water level..
Its all in the corner float mechanism. theres a red catch that must be released first (pushed out) and according to them (cos I couldnt see it) theres a white thingy right at the bottom of the tube that allows the tube to be pushed up and down. Its hard to explain, so its best to call HDB/ECTC if you need help.
So far things are getting flushed although its at a cost of 50% more water used(4L to 6L per full flush)
Going to change my toilet bowl again due to leakage.. 2nd time changing bowl, 3rd time changing tanks in 1.5yrs.. so sad..
kenlew8 glad to hear that your problem resovled
Yokoyoko what happened how come leak?
Edited by herbman76
how come now got advertisment one hee hee
Still waiting to sign up for Miotv bo?
There is a roadshow outside Shop and save for today n tml!!! Hurry!! Cos they will waive off all Activation and Installatio0n charges!!! Those who are still waiting to sign the BPL, please do so by TML till 6pm onli...
NO la.. EPL no star players liao.. lolz
Even the supplier oso don noe.. need to dismantle to c.. f up! zz
hmm.. good luck then :) hope everything turn out fine after the job. :rolleyes:
