Frosted Laminate Film On Windows - How To Peel Off?
The resale unit I bought comes with frosted windows in the bedrooms to block the sunlight or for more privacy. I was told that these may be just laminated films which can be slowly peel off.
I checked and found that the interior side of the window has that rough / frosted texture but the exterior (facing the outside) is smooth. However, I cannot locate an edge on this so-called film for peeling - so I wonder if this is a permanent fixture already.
Advice please. Really don't want to spend money to replace the windows.
Thanks.
If i am not wrong, the reason why you cannot see the edges because the flim is pasted on the glass BEFORE its inserted in to the window. If you do not wish to change the windos, you can actually look for contactors to change juz the glass.
OR you can try to use a penknife cut a small part and slowly pull out the flim,
There might not be any film at all.. just tainted glass
All of you are right - So I got my contractor to change the panes... And what a difference it makes!
