Installation Of Lock-set
Can check with you people whether any lobang for labour to install lock-set as our ID is charging us for the Labour.
Thanks
Thanks
We ordered our 2 bathroom doors with Good Wood Doors, then they changed our 3 bedroom & yard door lever locksets (which we bought from them ) FOC.
Otherwise, they charge $15 labour to change 1 lockset.
Saw on YouTube, can DIY ...
Thanks
Lock sets can be DIY... very easy...
my contractor offered to change it FOC for me.... i think yr ID is $$ faced.
i bought the new lock set myself and give it to my contractor.
after its been fixed, i further bought the DURO key hole lock for the main wooden door and i DIY this myself.
Thanks
Hi Hulk1010,
Yes sure can DIY....
Common Room Lock cost between $5- $10 with most hardware stores selling ard $8.50...
Main door lock will cost more depending on what you want... computer keys?, design n made... also the type... I think i may try to summarize the steps to change a lock set in 3 simple ABC steps: :dancingqueen:
Step A: remove door stopper
To change both lock... in general, have to open door, screw the 2 screws from the side of the door where the lock stopper comes out... you have to unscrew this using a "+" screw so that later the lock stopper can be remove later.
Yuppie you are 1 step closer to changing your lock step.... :dancingqueen:
Step B: remove Lockset/ Handle Capping
Oops... this may prove the b ethe most difficult part!
Then from in the inside of the door (it sure will be inside due to security reason), use a "-" screw driver to open the capping that is at the base of your door handle (usually theres a small catch to release this capping)...
But you succeeded!!! :yamseng:
If you can't .... :help: Just try gain after all you came this far....
Step C: Remove Lockset
Once you remove the capping. Can proceed to unscrew the lockset liao from the inside as you sure will see at least 2 screws mark to hold the lock set in place into your door.
Once lockset unscrew from inside... just pull the door stopper out first then pull the entire lockset out from the outside...
Sometimes you may need to further unscrew some parts for the outside before you pull the lock set out...
YUPPIE you are done!!! :dancingqueen::yamseng::drunk:
CONGRAGULATIONS!!!!
Hope the above is not too confusing :notti: as I learn the hardway when my contractor wants to charge me $150 for labor! :deal:
