fengshui-123
Ppgohbk Case
My iron gate are all with holes...so its ok?
can wait to change when you win 4D after putting water features at A and B :)
Can enlighten me on why certain areas windows can be open and certain can't?
long story, my post "Amazing and Simple Method" may answer some but not all. By the time you know all these you may already win many times toto/4D liao, so "JUST DO IT" first lah.
Edited by fengshui-123
I need to confirm the stove position with compass again as it might be only half inside the sector.
Sector A is available for water feature but not sector B since my TV is there...
will try and feed back any good luck.. :notti:
then use the half of the stove more often.
if I am you, I will change the iron gate, borrow loan shark money also must change, I think it is about $650 a piece for such alumiium gate. door is the MOST important. you spend much money to renovate, $650 is really nothing.
you can shift your sofa a bit, or to use two single seater sofa in between put coffee table, on coffee table put a small small water feature also good.
Both A & B have water feature is not 1+1, the power will be so much stronger than any one can imagine :)
