Need Advise On Id For 5 Room Resale
Hi All
Will be doing my reno sometime early July for my 5 room resale.
Been reading through the forum and kind of zero in (for now) the following ID:
1. Tau Interior
2. Plush Living
3. U Home
4. A&D
Anyone is welcome to recommend their ID who has done a good job for them.
Also need advise if a budget of 30K is able to cover all the following: :dunno::deal:
A) Common Items
1 Re-wiring for whole house c/w new switches , socket outlets , SCV points and Tel points
2 Replace stainless steel piping for whole house (Hot & Cold)
3 Re-painting of whole house using ICI paint
4 Chemical Wash of whole house
5 Supply labour for installation of lighting, WC, wash basin, ceiling fans and misc
6 Supply and install Window Grill for whole house
7 To provide haulage and clear debris from site
8 To plaster the wall if necessary
B) Recess Area
1 Hacking off floor tiles
2 Remove existing gate
3 Supply & lay heavy duty mat homogenous tile
4 Design & construct hanging shoe cabinet
5 Supply and install Main gate
C) Hall/Living/Dining Area
1 Hacking off floor tiles ****/dining area
2 Remove existing cabinet at dining area (non built in)
3 Design and construct TV Console with feature wall
4 Construct Cabinet for storage (to act as a store room) near dining area
5 Supply & lay heavy duty gross homogenous floor tile
D) Kitchen
1 Hacking off floor tiles & wall tiles
2 Remove existing kitchen cabinet, rubbish chute
3 Construct base for kitchen cabinet, fridge, washing machine
4 Apply Waterproofing
5 Supply and lay non-slip homogeneous floor tiles
6 Supply and lay wall tiles till ceiling high
7 Design & construct Kitchen Cabinet (L Shape)- Top and Bottom (with anti-slam mechanism)
8 Supply & install solid surface/ Granite for kitchen worktop area (L shape)
9 Supply and install stainless steel rubbish chute (flush to wall)
10 Install 1 set stainless steel Dish drainer
11 Supply & install 2 pair of Bamboo Stick holder
E) Master Bedroom
1 Remove existing built in wadrobe
2 Design and construct Built in wadrode integrated with TV Console
3 Overlay with laminated flooring
4 Supply & install naytoh door & door frame with lockset / stopper finishing
F) Bedroom 2 (Parent Room)
1 Design and construct Built in wadrode
2 Overlay with laminated flooring
3 Construct tv console (subject to space)
G) Bedroom 3 (Study Room)
H) Toilets (Master & Common)
1 Hacking of floor tiles & wall tiles
2 Remove existing WC
3 Supply and lay non-slip homogeneous floor tiles
4 Supply and lay wall tiles till ceiling high
5 Design and construct top cabinet
6 Design and construct Solid surface/ Granite Vanity top with cabinet at the bottom
7 Supply & install tempered shower screen / Half height Wall divider (subject to space)
8 Apply Waterproofing
9 Supply and install PD door
10 Supply and Install louvre windows with wire glass panels
I see that your contractor quote you laminate flooring.
Both laminate Flooring and solid wood flooring have their pros and cons but usually if you do not mind paying more, solid wood is the preference to compressed wood. Beside solid wood flooring allow you to do refurbishment (restoration by grinding the surface), which can be seen as a better long term investment.
If you are considering wood (e.g. parquet) flooring for your house, I can provide recommendation which you can save some money by working directly with the wood flooring specialist (reduce middle man markup).
If you are interest, you can email me at alfred.cheong@live.com
  • 1 month later...
U can call my friend who is an ID. Maybe he can give you some advise and quote..
If interested, u may PM me for his contact. :D
Hi All
1. Tau Interior
2. Plush Living
3. U Home
4. A&D
A) Common Items
B) Recess Area
D) Kitchen
E) Master Bedroom
Hi Guy,
in your selected 4, i found that lots people liken to A&D.
Hi All
1. Tau Interior
2. Plush Living
3. U Home
4. A&D
A) Common Items
B) Recess Area
D) Kitchen
E) Master Bedroom
For Plush Living.. Can take a look at this site http://www.renotalk.com/forum/index.php?showtopic=19630
I have sign-up with them. Find them very honest and professional. Will be getting my keys in June before reno start.
Din go to the other 3 which you mention, so cant comment on them.
Hi All
1. Tau Interior
2. Plush Living
3. U Home
4. A&D
A) Common Items
B) Recess Area
D) Kitchen
E) Master Bedroom
Hi there you may pm me and i can give you my sis id whom i personally think that he is quite good in his after sales service
Hi..
Does your sister Home interior designer? I want to offer some Home Decors items with cheap price
  • 2 months later...
Hi..
Like wat kind of decor n in wat sort of cheap price??
Hi All
1. Tau Interior
2. Plush Living
3. U Home
4. A&D
A) Common Items
B) Recess Area
D) Kitchen
E) Master Bedroom
Hi, hv u secured any ID 4yr flat
