Are The "big Rocks" Squashing And Stifling Me?
Hi
I stay in a Penthouse and the upper level is an open roof garden. My masterbedroom is on the lower level and above it is an open maintenance area.
As I have run out of space in my garden, I used the maintenance area to store 4 "big rocks" and a big pot of Frangipani plant.
The big rocks are in quotes because they are not real rocks. They look real but are mainly for ornamental purposes. They are made of hard plastic and are hollow.
I have not been good both health-wise for a while. I recently realised that the rocks were placed directly above my bed in the masterbedroom!
Is this bad? Could this have been the cause of my bad health? I ask this question because in Fengshui, I was told it is no good to have a beam on the ceiling which is above where you sleep or work.
Thanks a lot for any advice!
Hi
Hi
I don't think so. For example, in most buildings especially, there are many rooms which allow beds to have in one location. If that's the case, everybody should have bad health. Moreover they are made of plastics.
I think it is due to other reasons like your house feng shui.
Hi Butoot,
looks inside your room. Can you see the 4 big rocks, and the pot of fragipani?
If you can see it in the masterbedroom, and it creates a threat to you, then there's a possibility that it could be cause of your bad health. BUT if you dont see it, then most probably it is caused by some other things in the room.
And the beam on the ceiling refers to a drop down section that you see on the ceiling. If the stones and pots are above the ceiling, on the rooftop, then it doesnt refer to beams on the ceiling.
Hope it clarifies your doubts.
Felix Wong.
Hi
