myln02
My Reno Quotation.pls Help
here is my 4room 104sqm reno quotation from a contractor. can someone tell me is it reasonable ?
1 Hacking & Dismantling :
a To hack off two toilet wall and floor tiles $800.00
b To dismantle two toilet bowls , basin , doors & door frames -
c To hack off sink and stove support. $220.00
d To hack off 2 panels walls at kitchen entrance. $150.00
e Haulages & clearnce of debris include $200.00
f Chemcial wash after completion $120.00
2 Wet works :
a To supply & lay floor tiles at 2 toilets c/w waterproofing. $880.00
b To supply & lay wall tiles @ two toilets up to celing height w/o border $2,280.00
c To construct cabinet base. $180.00
d To touchup damaged wall and floor after hack off sink / stove and walls. KIV
3 Plumbing Works
a To supply and install cols stainless steel pipes at 2 toilets. $380.00
b Installation charges for 2 toilet bowls. ( toilet bowl to be supply by owner ) $140.00
c Installation charges for 2 ceramic basin at 2 toilets. ( sink to be supply by owner ) $120.00
d To supply & install inlet & outlet w/machine pipe $60.00
e Connection of kitchen sink. $60.00
4 Others
a To supply and install 2 nos. aluminium bifold doors. $380.00
c To supply and install false ceiling at centre of master bedroom. $380.00
d To supply and install L-box light holder **** hall. $520.00
e To supply and install wrought iron main gate. $420.00
f Electrical Works KIV
5 Carpentry Works
a To supply and install top kitchen cabinet. ( Est. 19ft x $80 ) $1,520.00
b To supply and install low kitchen cabinet. ( Est. 22ft x $80 ) $1,760.00
c To supply and install wooden top c/w stainless steel support. $280.00
d To supply and install solid surface. ( Est. 25ft x $60 ) $1,500.00
e To supply and install suspended tv console. ( 6ft x $80 ) $480.00
f To supply and install featured wall at tv area. ( 24sqft x $15 ) $360.00
g To supply and install casement wardrobe. ( 6.5ft x $80 ) $1,040.00
h To relaminate existing main door. $480.00
Total Amount : $14,710.00
Edited by myln02
Wow that's kinda cheap. Care to share the contact?
actually its a quote from my fren's fren whose is working as a contractor.so i
nt sure if he will give this kind of quote for others.sori abt that.izzit really cheap?
the kitchen cabinet total around 4k plus,consider cheaper than market rate?
Your casement wardrobe is super **** cheap lah!! .
he only quote the quotation bt didnt say wat material is he gg to use for wardrobe
or kitchen cabinet. nw worry he will give cheap material.
Is possible, if u see the Straits Times Classified Ads, u will see some carpenter offer direct factory carpentry, $45-$60pfr kitchen cabinet....cheap but the material and workmanship s***.
relaminate main door @ $480? Might as well change a new one....
" To touchup damaged wall and floor after hack off sink / stove and walls. KIV "
should have quoted u on this...
btw, u need so much carpentary? 19ft of top cabinets and 25ft of solid surface..?
i dun think will be very lousy since mine is $80pfr.jus cross my finger.
ya door i think might as well change new one.bt where can i find fire protected door less than 1k?
the touchup wall n floor,he say have to c hw first cause i nt doing my kitchen floor n the previous owner tiles think cant be found le so he say will try find similar one to cover.i dunn think will cost much right?
abt the carpentary,i nt sure.is he measure n quote one.my kitchen is those old type long one.doing a L shape.
half hr fire rated door: i was quoted between 800 to 950 from contractors. I see no problem in u getting it less than 1k.
if u had already confirmed with carpenter then nothing more can be done except praying? haha...do let us know of the outcome, he might turn out to be a gem! :)
UNbelieveable cheap, every thing is really cheap.
If the material and workman ship are of quality and trusted source, go for it.
material i will ask him tmr.hope cheap bt gd.
cause gt budget so gd or nt still have to tk since the prices are cheap.hope he is a gem.will update again.
Are you going to choose tile? Tile price can range from $1.5 to $9(or more) psf. Hopefully your contractor is not giving u the low grades ones.
Carpentry, solid ply or compressed?
Edited by chronograph
i think is solid ply.gg to choose tile this sun.i shall see.
