Pls Help On My Overhaul Quotation
B Hacking Works / Demolish Works
1 Supply labour & tools to hack existing marble flooring **** $600.00
2 Supply labour & tools to hack existing marble flooring at 3 bedroom $650.00
1 Supply material & labour to lay 600mm x 600mm super gloss homogeneous floor tiles **** c/w skirting (tiles price range $3.00 & below) $3,100.00
2 Supply material & labour to lay 600mm x 600mm super gloss homogeneous floor tiles at 3 bedroom c/w skirting (tiles price range $3.00 & below) $2,900.00
is it required to hack away the marble flooring and lay 600x600 tiles?
Ya man, the marble tile i have are too lovely but ugly. I wish it is in a nicer colour other than green. Had enuff of "green" during army days. =)
7 Supply material & labour to lay water proofing membrane at master bathroom $100.00
11 Supply material & labour to lay water proofing membrance at common bathroom $100.00
by right this should be one package. not spilt into 2.
I do agree, hmmm... Let me try to squeeze and qns him.
For your bathroom tiles and wall tiles if the current condition is really that bad then change. that might save u quite a bit too.
F Carpentry Works
1 Design & fabricate 20ft Top & Bottom kitchen cabinet c/w ABS trimming in laminate finish $2,200.00
What is the internal color for your kitchen cabinet. If white then will be expensive. You can ask for color interior.
Internal? u mean inside the cabinet? Most likely is white bah, quite standard. For concrete portion would be tiles.
G Plumbing Works
1 Supply materials & labour to run stainless steel inlet piping for whole house (cold pipe only) $600.00
2 Labour for installation 2 nos of wash basin at bathroom $100.00
3 Labour for installation 2 nos of water closet at bathroom $180.00
4 Labour for installation of kitchen sink & tap FOC
5 Laying of concealed drainage pipe for kitchen sink FOC
6 Laying of concealed drainage pipe for washer FOC
Sub-Total: $880.00
For the above only cold pipings? What if required hot?
Yap, cold only.
you are installing water heater or storage tank for the whole unit?
I decided to go with Water Heater, Storage tank consume too much power.
Edited by sunnytan31
