d'lotus
Air-con : Setting Remote A And Remote B
Hi guys,
I have 1 aircon each in the living and dining area (SANYO SAP-KM123GJ), which is very close to each other and when you switch on one of them, the other will be on too.
Understand you can set the remotes to A and B, but the manual that comes with it has no instruction how to do this - just asking you to contact the authorised dealer.
Have requested the building mngt to help but they keep saying their people is busy some other place.
I have downloaded another manual for another SANYO air-con and they have instructions to do this.... the first part is quite easy, but break the tab in the remote. The second part requires you to remove the jumper on the circuit board at the inner unit.
Anyone know how to access this circuit board, ie what to remove, etc?
alternatively, the indoor unit that u seldom use.. stick a toilet paper roll on top of the sensor, so that only a direct aim at it will trigger the aircon on. The toilet paper roll or similar hood will prevent stray signal from turning it on.
Hmmm.... simple solution.... will try this tonight :) Thanks
Hi guys,
i believe the circuit board shld be accessible after lifting the filter lid on the blower unit. and since it just say remove the jumper. there probably is only 1 jumper available?
