Is It Good
Hi i posted a topic just now but cant find it.I need some advise badly.I took this guy to renovate my house last year now using him again for my mum house but i am wondering if these prices are really favourale compared to others.Pls take a look and advise me he is fast and workman ship is gd but my mum needs to save as much as she can thks to her 47 ft run kitchen cabinet.
Kitchen
1[ To supply and lay kitchen floor tiles -950
2) To supply and lay kitchen wall tiles to ceiling height except behind cabinet -2300
3) To construct fridge ,washing machine and cabinet base 21ft run -380
4) To supply and install kitchen bottom unit with laminated finishing and ABS trimming 21ft run -1995
5) To supply and install kitchen top unit with laminated finishing and ABS trimming 21ft run -1995
6) To supply and install cabinet top using solid surface 21ft run -1365
7 To supply and install stainless steel dish tray c -80
8) To supply and install alum frosted glass -110
9) To supply and install kitchen middle unit 2ft run - 190
10) Labour charges to install built in oven -60
11) To supply and install long cabinet at piping area with laminated finishing and ABS trimming 5ft run -475
Common Toilet
1) To supply and lay toilet tiles till ceiling height.1250
2) To supply and lay toilet floor tiles -500
3) To supply labour to install toilet bowl and basin-160
4) To supply and install aluminum bi-fold door at toilet entrance-180
5) To change sewage pipe (change to plastic) -600
6) Labour charge to install 2 nos of toilet accessories-60
7) To supply labour to install 1 nos gallon heater.-60
Master Toilet
1) To supply and lay toilet tiles till ceiling height.-1250
5) Labour charge to install 2 nos of toilet accessories-6o
Carpentary
1) To design and fabricate full height casement wardrobe for Master bedroom 5ft run -975
2) To design and fabricate full height L-shaped casement wardrobe for c/m rm1 bedroom 10 ft run-1950
3) To design and fabricate full height L-shaped casement wardrobe for c/m rm1 bedroom 10 ft run-1950
Others
1) To rerun stainless steel cold piping-580
2) To run water heater piping-380
3) To hack 2 toilet wall and floor.To hack kitchen wall and floor. To hack kitchen cabinet.-1800
4) To spray rockstone on walls.Painting of ceilings.-1700
5) To plaster living room wall and toilet ceiling -300
6) To remove wall paper -400
7) To supply labour to repolish existing terrazzo flooring-990
8) To supply and install white aluminum window for living,3 bed rooms and kitchen-2066
9) To supply and install white aluminum window grills for living,3 bed rooms and kitchen-911
10) To supply and install 3 side L- box cornice in living room 12 inches-300
11) To supply and install 1 classic door at store room 160
12) To supply and install stainless steel rubbish chute-180
13) Installation of basin at solid top-100
14) To box up 3 no. of windows above c/rms and storeroom door.-120
15) To supply labour and change main door lock set-100
16) To supply labour and change main gate lockset- 100
17) To suppply and install Samsung system 3 aircon - 1800
18) Haulage -200
Electrical wiring
1) Living room - total- $2732
To change position and supply new MCB board -
4 down light wiring
4 down light installation
2 down light switches
1 ceiling fan wiring
1 ceiling fan switch
1 ceiling fan installation
1 ceiling light wiring
1 ceiling light switch
1 ceiling light installation
1 telephone point
1 scv point
2 double plugs
2) master bedroom-
1 aircon point
1 scv cable point
2 double plugs
1 toilet light wiring
1 toilet light switch
1 toilet light installation
1 bedroom light wiring
1 bedroom light switch
1 bedroom light installation
3) Common room 1-
2 double plugs
4) Common Room 2 -
2 double plugs
5) Kitchen
2 kitchen lights wiring
2 kitchen light switch
2 kitchen light installation
1 single point
3 double points
1 gallon heater point
FOC
1) To hack tiles at hall at kitchen arch
2) To supply labour and material to errect hall and kitchen arch.
3) To hack existing cornice in living room
4) To construct 4 ft run extended washing machine base.
5) To hack door frame at master bedroom toilet.
6) To supply and install cooker hob and 3 knob cooker
7) HDB Permit
8) Waterproofing for kitchen and bathroom
9) Chemical wash for kitchen and 2 toilets upon completion
