Repair Of Ceiling
Hi all,
I recently made the major mistake of drilling into my ceiling at the wrong place
Now, there is a gaping hole there and I have absolutely no idea how to recover from the faux pas.
One of the solution that I have is...
$9.90 epoxy sold at Shell. Seems to be easy enough. Simlpy mix, and patch... Then paint over the patched hole.
Any better suggestions?
  • 2 months later...
You did not mention the material of the ceiling. Is it concrete or plaster board?
What is the size and depth of the hole?
Edited by fierydragon
Hi all,
If the hole is big and deep, then you can buy cement and mix with water and sand. The mixture should be like 1 part of cement, 2 parts of water and 3 parts of sand.
If the hold is only a small one, then you may want to buy those ready made patty to cover it. It cost only $2 plus per container....
