How To Install An Lcd Tv Wall Mount
Hi All,
Can any tell me how to install an LCD TV Wall Mount?
I already got the Wall Mount for 32 inch.
What tools do i need?
hammer drill, concrete drill bit, spirit level meter, cordless screwdriver, measure tape, vacuum cleaner.
Thanks for sharing.
For hammer drill,Can black and decker 700w impact drill do the job for new HDB.
btw what the use for spirit level meter.
Do i need to buy those plastic wall plug as it didnt come with it when i got the Wall Mount?
Thanks for sharing.
700w is sufficient. but have to be careful which parts of wall can be drilled. u dun want to drill into structural columns.
spirit level meter is to check if u mount the brackets straight or not. best to borrow a laser leveller so that tge marked out holes will always be straight. wall plugs will have to be bought so the mounting will be strong.
thanks got it. but how to know is it structural columns?
You will need to refer to your floor plan, those walls that are in bold are structural columns.
Thanks for the information. But i notice most of the walls are bold meaning to say i cant do any drilling on these wall?
  • 4 weeks later...
I believe you can drill on these walls since alot of us have our aircon fancoil units mounted on the structural walls too.. Those are mounted with drilling and screws.. But take note, its not going to be easy on the drill or you.. Other bros might be able to help you with the exact ways to go about it..
