kunxeno
Aircon Pipings
Hi
Why would we need to recommend to upgrade from (24SWG) to (23SWG)
0.56mm (24SWG), 0.61mm (23SWG)
I undderstand from some ppl that 24swg the metal is thicker.....
Anyone can advise?
Hi
As I know, when then metal wall is thicker, it has less chance to break during bending area, normally when customer upsize the piping size, the insulation should also upsize together, means less chance condensasion water dripping out. I was advised for the Inverter model aircon need to change to thicker material as gas pressure also higher compare to non- invertor.
Anyone can advise?
