Can Someone Help Me To Review My Quote?
Hi jonatan1312,
Are the above quotation given by your contractor or u yourself is a contractor?
Can you pls pm me the contact?
I'm currently looking for a contractor for my 4A.
Don't really need an ID as we've basically got the design that we wanted already.
Thanks!
LIVING/DINING
1 To design & construct (est.L9.5ft) full height shoe cabinet c/ storage cabinet using solid-ply laminate $ 3,040.00
2 To design & construct (est.L8ft) half height TV console using solid-ply laminate $ 1,440.00
3 To design & construct (est.L3.5ft) full height cabinet using solid-ply laminate $ 1,050.00
4 To design & construct (est.L6.5ft) half height study table using solid-ply laminate $ 1,170.00
TOTAL LIVING/DINING $ 6,700.00
MASTER BEDROOM
1 To supply labour to dismantle existing door & door frame $ 200.00
2 To supply labour to make good to damaged area $ 150.00
3 To supply & install veneer door c/w lever handle $ 350.00
4 To supply labour to construct (est.L8.5ft) full height partition wall using adjacent board w/paint finish $ 800.00
5 To design & construct (est.L10.5ft) full height casement wardrobe using solid-ply laminate $ 3,800.00
TOTAL MASTER BEDROOM $ 5,300.00
BEDROOM 2
1 To supply & install veneer door c/w lever handle $ 350.00
TOTAL BEDROOM 2 $ 350.00
BEDROOM 3
2 To supply & install veneer door c/w lever handle $ 350.00
TOTAL BEDROOM 3 $ 550.00
MISCELLANEOUS WORKS
1 To paint whole unit using ICI/NIPPON paint to all walls and piping (unlimited amount of colours) $ 1,700.00
2 To lay cardboard protection for working areas $ 300.00
3 To provide general cleaning for entire unit $ 300.00
4 To clear and discard debris $ 300.00
TOTAL MISCELLANEOUS WORKS $ 2,600.00
PROFESSIONAL SERVICES
1 Design consultation
2 Space Planning
3 3D perspective and detail drawing
4 Material and color proposal
5 Site Management/Project Management
TOTAL PROFESSIONAL SERVICES $ 1,500.00
GRAND TOTAL (excl.GST) $ 17,000.00
GRAND TOTAL (include GST) $ 18,190.00
GRAND TOTAL (include GST) after discount $ 16,500.00
your quote seem quite high. if you already know what to do to your new house, get a contractor will be much cheaper. my house was done by a contractor as i already had an idea of the designs. for the 5 items stated in "Professional Services", you are able to get it cheaper by consulting a freelance designer or drafter who will provide you with the drawings you need to go to a contractor. As all ID firms will urge to close deals pretty badly, they always make these services seem very expensive, which is actually not true. i only pay less then a thousand for that. i can intro you my drafter. Need pm let me know ba. best part, no GST! lol. cheerz. happyRENOV
Jonatan,
My contractor quoted me $200/ft run for my b/rm wardrobe, and it's sliding type with mirror, so if it's 10.5 ft, that works out to 2100.
hi all, i met up with several ID recommended from this forum, and was wondering if this package is expensive? it covers most of the items
required for my house. other reno package i receive are not as detail as this company.
mine is a new 4room standard flat. the package price is $14288 and they are giving me free selected rinnai / fujioh hood worth $888 or $888 bathroom/kitchen/lighting vouchers.
B MASONRY
1 SUPPLY & LAY 600X600 SELECTED HEAVY DUTY HOMOGENEOUS FLOORING @ LIVING/DINING AREA ($3.50 W/GST)
2 SUPPLY & LAY 600X600 SELECTED HEAVY DUTY HOMOGENEOUS FLOORING @ STORE ROOM ($3.50 W/GST)
3 SUPPLY & LAY SELECTED LAMINATED FLOORING AT 3 BEDROOMS (WITH MATCHING SKIRTING)
(OPTIONAL TOP UP OF $200 FOR 600X600 SELECTED HEAVY DUTY HOMOGENEOUS FLOORING ($3.50 W/GST) PER BEDROOM)
4 TO CONSTRUCT 50MM KITCHEN CABINET BASE
5 TO CONSTRUCT 50MM WASHER BASE
6 TO CONSTRUCT 50MM FRIDGE BASE
7 TO CONSTRUCT SHOWER KERB AT BATHROOMS
8 TO CONSTRUCT MAIN ENTRANCE KERB
C PLUMBING
1 EXTENSION OF STAINLESS STEEL PIPING TO NEW KITCHEN SINK & WASHING MACHINE POSITION
2 TO SUPPLY LABOUR FOR INSTALLATION OF INSTANT HEATER / STORAGE TANK (PROVIDED BY OWNER)
3 TO SUPPLY LABOUR FOR INSTALLATION OF ALL BATHROOM ACCESSORIES (PROVIDED BY OWNER)
4 TO SUPPLY LABOUR FOR INSTALLATION OF KITCHEN SINK & TAP (PROVIDED BY OWNER)
5 LAYING NON-CONCEAL DRAINAGE PIPE FOR KITCHEN SINK
6 LAYING NON-CONCEAL DRAINAGE PIPE FOR WASHING MACHING
D CARPENTRY
(All CABINETS COMES WITH SOFT CLOSING HINGES , COLOURED INTERIOR LAMINATE & ABS TRIMMING)
1 DESIGN & FABRICATE 10FT BOTTOM KITCHEN CABINET BY USING SELECTED LAMINATED FINISHING
2 DESIGN & FABRICATE 10FT TOP KITCHEN CABINET BY USING SELECTED LAMINATED FINISHING
3 TO SUPPLY & INSTALL SELECTED 10FT SOLID SURFACE WORK TOP
4 TO SUPPLY & INSTALL SELECTED DESIGNER HANDLES (IF NEEDED)
5 TO SUPPLY & INSTALL SELECTED STAINLESS STEEL DOUBLE LAYER DRAINAGE TRAY
6 TO SUPPLY & INSTALL SELECTED CUTLERY TRAY
7 TO PROVIDE 1 NOS SELECTED GLASS PANEL FOR DRAINAGE TRAY AREA
8 TO SUPPLY LABOUR TO INSTALL COOKER HOOD & HOB (PROVIDED BY OWNER)
E CEILING
1 DESIGN & FABRICATE DESIGNER CEILING / L-BOX FOR LIVING AREA ONLY
F ELECTRICAL (ALL ELECTRICAL WORKS ARE NON-CONCEAL)
1 TO ADD ELECTRICAL POWER POINTS (IF NEEDED)
2 TO RUN NEW LIGHTING POINTS AT CARPENTRY (IF NEEDED)
3 TO RUN NEW LIGHTING POINTS AT CEILLING WORKS (IF NEEDED)
4 TO SUPPLY LABOUR TO INSTALL WHOLE LIGHTS FITTINGS (PROVIDED BY OWNER)
5 TO ADD/RELOCATE SCV POINTS (IF NEEDED)
6 TO ADD/RELOCATE TELEPHONE POINTS (IF NEEDED)
G PAINTING
1 PAINTING OF WHOLE HOUSE WALL BY USING SELECTED PAINT
(6 DIFFERENT COLOURS SELECTION FROM ICI DULEX ALL, ICI PENTALITE, NIPPON VINILEX 5000)
(WITH 1 BASE COATING + 2 PAINTS COATING)
2 PAINTING OF WHOLE HOUSE CEILING / FALSE CEILING BY USING NORMAL WHITE PAINT
3 TO SUPPLY LABOUR & MATERIALS TO SEAL ALL UNWANTED HOLES BEFORE PAINTING
H MISCELLANEOUS
1 TO PROVIDE ACID WASH & GENERAL CLEANING TO WHOLE UNIT (FLOORING ONLY)
2 TO PROVIDE FLOOR PROTECTION CARDBOARD
3 TO PROVIDE LABOUR TO INSTALL WHOLE HOUSE ACCESSORIES
is ur homogenous flooing tile for the whole flat or just for living room? if whole flat, a lot cheap than my quote. one of my ID quote me 2,250 for living room only...
For painting works, I've got this Myanmar guy charging $300 to paint my 4room flat. But u have to get your own paint. Sure cheaper than those offered in the market. PM me if u need.
How is the works and attitude?
I bought a 3NG, a total a 796sqft. This is the quotation that i might wan to sign with the ID house, but let me know whether it looks ok, reasonable or something fishy is going on.
I didnt do my kitchen and toilet wall tiles as to save some budget for other things, which could cost another $4000. your help is much appreciated!
Living, Store, 2 Bedrooms & Utility Room
Hacking of existing flooring (Living, Dining, Passageway & Store) $342.00
Hacking of existing flooring (2 Bedrooms) $450.00
Hacking of existing flooring (Utility Room) $90.00
Hacking of wall between MBR and Store $300.00
Seal up existing entrance at store room w/ Partition Board + Rock wool $160.00
Supply & lay 600x600 polished homogeneous floor tiles c/w skirting $3,500.00
Kitchen
Hacking of existing wall between living & kitchen $400.00
Hacking of existing floor & wall tiles $333.00
Hacking of existing cement mortar base $120.00
Construct 2" thick concrete base for fridge, washing m/c & cabinet $250.00
base c/w tiles finish (Washing m/c base area < 20sqft)
Supply & change 1 no. stainless steel flat rubbish chute $100.00
To supply & lay HDB approved extruded foam not exceeding 30sqft $310.00
Supply & apply waterproofing membrance at kitchen $200.00
To connect in/outlet UPVC piping for sink & washing m/c $100.00
Supply & lay homogeneous floor tiles ($3.20 psf app 140sqft) $1,200.00
Supply & install Paint Glass Backsplash (< 11'L) $680.00
To make good wall after hacking wall between kitchen & living rm $200.00
2 nos Toilets
Hacking of existing floor tiles, fittings, accessories & door frames $140.00
Supply & lay waterproofing membrane to 2 toilets $200.00
Supply & lay homogeneous floor tiles to both toilets $760.00
Construct 2 nos shower kerb w/ tiles finish in both toilets $100.00
Supply & install 2 nos frameless glass door for both toilets $970.00
Plumbing Works
Supply & replace stainless steel piping for kitchen & 2 bathrooms (cold point) $550.00
Supply labour to install 2 sets of sitting water closets c/w dual flush & soft close cover $150.00
Supply labour to install 2 no. of wash basins and taps $120.00
Hot point 6 nos (2 MBR toilet, 2 Common Toilet, 1 Kitchen, 1 Washing m/c) $225.00
Supply labour to install 2 sets of bathroom accessories $120.00
Supply labour to install kitchen sink & tap $70.00
Painting Works / Plastering
To paint whole house (interior walls & celing), using ICI or Nippon Emulsion paint (5+1 colours) $1,000.00
To paint all door frames, gate & piping using ICI or Nippon Enamel paint together wt above
Plastering for whole house (+$400 for kitchen) $1,200.00
Ceiling Works
Construct false ceiling at passage way $55.00
Construct false ceiling at WIW $85.00
Construct false ceiling at Dining area $325.00
Construct false ceiling c/w cove light for living area $550.00
Construct false ceiling c/w cove light for MBR $640.00
To supply & install Fibre Plaster to box up piping in Living & Kitchen $250.00
Carpentry Works
Design & fabricate WIW w/o doors interior colour PVC (not exceeding 9') $2,250.00
Construct partition wall for pocket door @ entrance WIW $185.00
Design & fabricate pocket door w/ laminate finish @ WIW entrance (not exceeding 4') $780.00
Design & fabricate 11ft Top kitchen cabinet (laminated) w/ ABS trimming $1,320.00
Design & fabricate 15ft Bottom kitchen cabinet (laminated) +ABS with CERA solid surface counter top $3,150.00
Design & fabricate 5ft full height storage cabinet (laminated) $1,100.00
Supply & install stainless steel dish drainer $100.00
Electrical Works (Provisional)
Supply & Install Double Power pt 9 nos @ $55/no $495.00
Supply & Install Single Power pt 2 nos @ $45/no $90.00
Supply & iInstal Telephone pt 3 nos @ $45/no $135.00
Supply & Install Aircon pt 1 no @ $90/no $90.00
Supply & Install heater pt 1 no @ $90/no $90.00
Supply & Install Hood pt 1 no @ $45/no $45.00
Supply & Install SCV pt 3 nos @ $90/no $270.00
Supply & install Lighting points 9 nos @ $38/no $342.00
Supply & install LAN pt 4 nos @ $25/no $100.00
Supply & install Ceiling Fan pt @ $38/no $38.00
Supply & install DB 1 no @ $350/no $350.00
Miscellaneous
Protection of flooring with corrugated cardboard for affected areas (Lumsum as below)
Chemical washing for whole house (Lumsum as below)
General cleaning upon completion of works (Lumsum as below)
Haulage service (Lumsum as below)
Disposal of renovation debris $600.00
To seal the window area above bedrooms doors $100.00
change bedrooms doors $360.00
To seal the master bedroom aircond $100.00
Construct Half Ht wall not exceeding 5.5' $200.00
total $28,535.00
I find bathroom quite reasonable. Mind to share the contact?
  • 1 month later...
Hi mesherry,
Please pm me your contact. The toilet package is indeed very competitive. Thanks.
  • 4 weeks later...
Kitchen
2 nos Toilets
Plumbing Works
Ceiling Works
Carpentry Works
Miscellaneous
total $28,535.00
hi mesherry, mind if you let me have your electrician contacts? my number is 90053357. Thanks.
Regards,
Jack
Hi Guys of RT,
Just to share and also get some feedback on electric works for my 5 room flat.
Description Each
Opennet PVC piping conceal $90
Lighting point, Covelight and downlight $42
SCV point Conceal $150
Telephone point conceal $60
T5 first light point $42
Looping T5 $15
Ceiling fan point and install $80
Install lights services (Owner suppy own light) $10
Supply & Install Double Power $60
Hob point $95
2 way switch $60
I'm looking for some other quotes. I believe mine is trying to "chop" me.
Kitchen
2 nos Toilets
Plumbing Works
Ceiling Works
Carpentry Works
Miscellaneous
total $28,535.00
Please PM me the contact with many thanks
Jay
