Do The Grount Lines Of Your Wall Tiles And The Floor Tiles Align?
just want to check if your wall tiles grout lines and the floor tiles grout lines are aligned. Mine is not aligned and the tiler and contractor say cannot align because my kitchen uses 600 X 300 wall tiles while floor is 300 X 300 tiles. So every 2 tiles = 1 wall tiles and the grout lines are 2mm, so cannot align properly.
Is this true?
The MBR bathroom is also the same. I was told cannot align to allow the tile to allow water to flow down the drainage and not be trapped. Is this true?
My kitchen floor uses 300 X 300 while my kitchen wall uses 600 X 300.
If you stand facing the kitchen window, the tiles on the left and right wall are lay horizontally across the left wall, wall on top and under the kitchen window and right wall. The floor tiles are align 2 tiles with 1 wall tile, the alignment is swee swee; the only part not align is near the edge, either on the left side or right side.
Sometimes not very obvious cos there are break in the view as the cabinets or appliances can cover the misalignment.
Edited by albertchng
