kunzzy
Need Light Ideas For My Living Room
Hi Everyone, I need your ideas of what sort of lights to use for my living room.
I have a cove light on top which is its projecting out to the living room which is bright enough to cover the living room but I feel that something is missing as my living room walls are a little dark
I was thinking of adding this living room cabinet with the light coming out at the back. Do you think it will make my living room more attractive?
Edited by kunzzy
Adding backlight is an effective approach to brighten up the living room wall where a number of decorative items are placed.
Apart from the backlight installed on the bottom deck cabinet, you can consider a hollow internal lit with LED strip/module for the 2nd-tier cabinet, then cover the cavity with frosted perspex to create a glowing effect.
For the top deck, either track light installed on the ceiling or LED strip similar to that on the bottom deck will be a good idea.
Take note to choose moderate brightness light for this area to avoid visual distraction.
