Advise My Electrical Quote For New 4 Rm Hdb
Hi ppl,
Can anyone advise me if my electrical quotation is reasonable? many thanks.
NO DESCRIPTION QTY U/PRICE AMOUNT
2 13A double socket outlet 3 $60.00 $180.00
3 10A lighting switch point 24 $32.00 $768.00
5 cat 6 data point 1 $100.00 $100.00
6 television SCV point 2 $100.00 $200.00
11 cooker hood point(20A heater switch ctrl) 1 $55.00 $55.00
12 cooker hob point(20A heater switch ctrl) 1 $55.00 $55.00
19 relocate double socket(less than 8 fit) 4 $40.00 $160.00
20 relocate switch point (less than 8 fit) 2 $30.00 $60.00
22 relocate lighting point(less than 8 fit) 5 $20.00 $100.00
26 install light fitting 35 $9.00 $315.00
28 install hanging light 1 $40.00 $40.00
29 t5 looping point 20 $20.00 $400.00
31 connet heater point 1 $60.00 $60.00
32
33
34
total $2,493.00
Looks okays to me.
:yamseng: ,
Mike
Mike,
Noted with thanks.
I manage to bring the price down to $2250. Think I will go for it since it's introduce by my ID and I believe they should work better together due to previous projects done together.
Mike,
Noted with thanks.
good luck!
hi,
just checking if yours is the new hdb flat with concealed wiring?
if yes, can i know if there's any hacking works involved for the relocation of your powerpoint and switches?
if there's hacking works, is it a separate cost other than the amount you listed?
thanks! :)
The quote is reasonable to me.
Mine Which a EM $4k included sockets and switches.
But I didn't see your quite for yr DB which might cost at least $400
Yup include the hacking and supply of the sockets n switches and also the wirings will be conceal . Mine is a new flat in punggol . As for db. He did not mention anything about it , guess new flat no need ba .
Hi storm79..pls pm me the electrician contact..thanks
Hi 156,
I will be starting my renovation soon and prefer to introduce after I have seen his works, once done, I will get back to you. cheers!
  • 2 years later...
Hi Storm,
how was your electrician for your bto? is the workmanship ok? can u pass me his contact? thank you!
Hi ppl,
32
33
34
total $2,493.00
Hi Bro,
Can PM me his contact?
How is his workmanship?
Many thanks in advance.
  • 1 month later...
