Bosch Induction Pmi968Ms - What Amp?
Any members can confirm for Bosch Induction Hob model PMI968MS - what is the amp plug requirement?
Went to 3 different places all gave me different answers since it was not stated in catalogue.
Harvey Norman - can connect to 15amp but performance will be affected
Gain City - need 30 amp plug
Best Denki - normal 13amp plug is sufficient
Pls help ... Thanks to all in advance.
try pm terry 87 he the bosch person to go to
Edited by dodofish
Thanks for the info - much appreciated
  • 2 months later...
WeikiRee, did you manage to get an answer for this? thanks
- Front left: 2.2kW with booster 3.3kW (Ø210mm)
- Front right: 1.4kW with booster 1.8kW (Ø150mm)
Normal 2.2kW + 1.4kW = 3.6kW (3600 / 220) = 16Amps
With Boost 3.3kW+1.8kW = 5.1kW (5100/220) = 23Amps
So if u use 15 amp it will work for normal usage but if u use boost then it will trip
if Old HDB with then not advisable other than only use one side ...
Thats what i understand... Hope this helps...
