Advice Needed On Covering Of Floor Trap Below Kitchen Sink
Hi all, I have a L shaped kitchen & my sink is located at the shorter L side. My washing machine is located juz besides the sink. All water from the sink & washing machine drains to a common pipe & the floor trap is located in the cabinet beneath the sink. This floor trap has been covered up by a piece of thin plywood. My kitchen cabinet sits on a cement base.
My question is: is this the correct way to position the floor trap? After removing the plywood cover, I realised due to water vapour, it has turned mouldy. How should I prevent this or should I use another material to cover the floor trap?
Really appreciate your advise or how it's being done in your home. Thanks all
anybody? I only noe some folks here constructed kitchen sink base using concrete/tiles
Use a piece of tile to cover the floor trap.
  • 2 months later...
My contractor also use a removable wood to cover the floor trap.
I notice there are some mould at the surface that face the floor trap of the removable wood.
I went to buy a anti mosquito valve to place at the floor trap and use that wood to cover trap
http://www.flickr.co...N02/2182726146/
something like this
I think HW shop or those ABC shop sell at $2.50.. I think
i can't find floor trap from hardware shop leh
  • 2 months later...
I think we have the same situation as yours, except our outlet is under the fridge.
Trapdoor under fridge
The tiler used a piece of leftover tile from the renovation to cover over the floor trap.
But if you did not keep any, I suppose any other tile is better than plywood.
Try to go to the location, where contractors buy their hardwares.
Hardwareshop
