flyersummer
Any Electrician To Recommend?
William is confirmed not a relative or friend of mine. I have recommended him to my relatives and friends, and they are all very happy with his work. Please call him at 9150xxxx. Quotes are free! I emphasize that he uses quality cables. 5th year after major renovation. Cheap electrical wires from other electricians starting to melt and burn sockets. Just called him last week for fix. Highly recommended!!!!!
If you use his electrical services, please feedback here.
Edited by leyenda
  • Like 1
I have been living in a relatively old home with my family since long. There was a bond that we had with this particular home that we bought it. We had problems with the old wiring that existed that we had home rewiring done by a team in Orillia <link removed> . They started of with small wiring checkups and ended up with excellent rewiring solutions. Hope this will be of some help!
My quote is as follows(5rm rewiring)
To supply labour to dismantle existing lighting fixture and wires. - FOC
To supply and install new lighting point. (includes switches Clipsal KB model) - $24 X 40 = $960
To supply and install new 13amp power point single. - $40 X 1 = $40
To supply and install new 13amp power point double. - $45 X 21 = $945
To supply and install new 20amp point for Heater. - $70 X 2 = $140
To supply and install new 20amp ISO point for Aircon - $100 X 1 = $100
To supply and install new Telephone wiring point. - $45 X 5 = $225
To supply and install new SCV wiring point. - $95 X 5 = $475
To supply and install new Hood & hob point. - $70 X 2 = $140
To supply and install new CAT 6 Lan point. - $120 X 5 = $600
To install ceiling fan - $35 X 1 = $35
To install lightings - $10 X 40 = $400
To install new Hager 18way PVC DB BOX with; 40A MCB, ELCB and MCBs - $600
To supply and install Earthing for Gas & water pipe - $120
The in house brand he is providing is Clipsal KB model (white)
TOTAL DAMAGE: $4780
Less discount: $280
TOTAL: $4500
Happy with the job done. Hope this info helps.
Hi wwz,
Can you send me your electrician contact if you still have it with you?
my email: joooo8@gmail.com
thanks.
Joanna
Thank you for giving Mr Keong's no!
we engaged him to do our whole warehouse and has very good workmanship and keep his words till the end. he also gives us good price. i did my house with another electrician by my ID and that guy is nowhere like Mr keong
I hardly login to renotalk nowadays ever since i completed my renovation. However, i took the trouble to login here to spread good services of an electrician.
I got the contact of an electrician Keong (9383xxxx) from one of the posts here..
What i like about this electrician:
1. Cheerful and positive attitude.
2. Very reasonable and good price - i enquired about 5 electricians for installing ceiling fan and replace a light fixture. He is the cheapest among them.
3. Quick clean job. They came in a pax of 3. Fast hand fast leg.
4. He is not calculative. He installed a kitchen light fixture (provided by me), but found that the it was faulty. The solder joint gave way. He attempted to fix it, but in vain. I quickly rushed to the nearby shop and got another light fixture. Size different. He had to dismantle the newly installed one, drill holes and installed a new one again, but still, he charged me for the price which had agreed earlier, which is $15.
At the end of the job, he charged me $130 in total (extending existing wiring and installing ceiling fan with fan hook, installing a new 13amp power point, installing a new light fixture). I gave him $150 and asked him to keep the change. Good services deserved more and i hope this will encourage them to keep up the good services.
The only drawback is that there's some delay. He promised to come around 10am but only turned up at about 1pm. Nonetheless, he did bother to call me and inform me about his late arrival.
Hi all - can anyone PM me the contact nos of Mr Quek, Mr Ong and Keong? Urgently need an electrician.
Also, has anyone done electrical testing? An electrician can provide this service correct?
Thanks all in advance!
Guest Wiseguy Ho
Just found one electrician recommend by my friend, his service not bad too, can try to call +65 8316 xxxx
Him one can you please share your electrician contact?
