tjhs_87
Renovation Quote
Hi guys, how much will this usually cost? appreciate your feedback :good:
1200 sqft 3 bedroom apartment.
1.0 DESIGN SERVICES:
1.01 Interior design & space planning with perspective
F.O.C
drawings.
1.02 Furniture layout plan, materials & colours proposal.
1.3 Site co-ordination to oversee the renovation.
1.4 Application of renovation permit.
2.0 GENERAL WORK:
Supply labour and material to:
2.1 Hack off existing wall tiles at Master Toilet, Common Toilet & Yard Toilet.
2.2 Hack off existing floor tiles at Kitchen, Master Toilet,
2.3 Dismantle existing kitchen cabinets and all Bathrooms vanity cabinet, Living TV feature & console & a Divider
between Living & Dining area.
2.04 Dismantling existing wardrobes for all Bedrooms
2.05 Dismantling existing long bath at master bathroom .
2.6 Haulage & Debris removal services
2.7 Lay corrugated paper for protection during renovations
2.8 General Cleaning after renovation work
MASONRY WORK: (All tiles quoted max $3.00)
Supply labour & materials to :
3.0 Living & Dining Area. (Homogeneous or Ceramics)
3.01 Compound Leveling flooring ****/Dining area. $
3.02 Install selected Vinyl tiles ****/Dining area. $
3.03 To sand & varnish existing teak parquet floor c/w solvent-
based varnish at Master Bedroom & Bedroom 2 & 3 plus $
touch up work.
Kitchen Area.
3.04 Lay 300mm x 300mm Non-slip homogeneous floor tiles
c/w construction of water proofing membrane.
3.05 Lay 300mm x 600mm or 2 tone ceramic wall tiles ceiling $
ht at max 1.8m.
3.06 Construct 50mm thk cement base for kitchen cabinet . $
Service Yard Area.
3.6 Lay 300mm x 300mm Non-slip homogeneous floor tiles
at yard area & utility room c/w construction of water Optional
proofing membrane.
3.07 Construct 50mm thk cement base for washer. $
Master Bathroom
3.08 Lay 300mm x 300mm Non-slip homogeneous floor tiles
3.09 Lay 300mm x 600mm or 2 tone ceramic wall tiles ceiling $
Common Bathrooms
3.10 Lay 300mm x 300mm Non-slip homogeneous floor tiles $
3.12 Lay 300mm x 600mm or 2 tone ceramic wall tiles ceiling $
height.
Yard Bath Room
3.12 Lay 300mm x 300mm Non-slip homogeneous floor tiles $
3.13 Lay 300mm x 600mm or 2 tone ceramic wall tiles ceiling $
height.
Sub-Total $
4.0 FIBROUS WORK:
Supply labour & materials to:
4.01 Box up existing Glass Block L-Shape at Master Bedroom LS $
using Gypsum Board.
4.02 Box up exisitng Glass Block at existing Dining Area using LS $
Gypsum Board.
Sub-Total $
5.0 PLUMBING WORK:
5.01 Labour & materials to conceal copper cold & hot inlet $
piping for all bathrooms
5.02 Labour to install upvc drainaige pipe for kitchen sink & $
washing machine.
5.03 Install upvc drainage pipe for 3 bathrooms. $
5.04 Labour and tools to install 3 sets of sitting WC for both $
bathrooms.
No. Description Amount
5.05 Labour and tools to install 2 sets of shower head for all $
bathrooms.
5.06 Labour and tools to install 2 sets of wash basin for both $
5.07 Labour and tools to install bathroom accessories. $
5.08 Labour and tools to install 2sets of storage/instant heaters. $
Sub-Total $
6.0 PAINTING WORK:
6.01 Paint whole house with ICI or Nippon paint including
interior wall & ceiling, all expose pipes, doors & door $
frames.
Sub-Total $
7.0 DOOR & FITMENT:
7.01 Install Swing & Slide Door at Master Bathroom. $
7.02 Install 10mm thick clear tempered glass shower screen at $
Master Bathroom.
7.03 Install 10mm thick clear tempered Shower Panel at $
8.0 CARPENTRY WORK:
Supply labour & material to:
KITCHEN AREA
8.1 Design and fabricate ceiling height ht Kitchen Top approx 20 ft laminate finish with ABS door trimming using 18mm solid plywood in internal white pvc finish c/w soft closing hinges c/w cutlery tray and stainless steel
Design and fabricate ceiling ht Kitchen Bottom approx
20ft laminate finish with ABS door triming using 18mm
8.02
solid plywood in internal white pvc finish c/w soft closing hinges.
8.03 Design and fabricate Tall Ladder in laminate finish in $
internal white pvc finish.
8.04 Install selected solid surface worktop approx 17ft c/w $
front profile & backsplash.
8.05 MASTER BEDROOM / BATHROOM
Design and fabricate suspended vanity cabinet in selected
laminate/veneer finish in internal white pvc approx 6ft in $ 1,800.00 selected solid surface top c/w mirror.
8.06 COMMON BATHROOM
laminate/veneer finish in internal white pvc approx 4ft in $ 1,200.00 selected solid surface top c/w mirror.
Hi, I had my 4room flat renovated by Jiamei Furnishings a registered company.
They indeed amazed me by having a good craftsmanship at a Cheap & Reasonable pricing.
If your interested, you can email me & will send u their details :
pamelatan82@gmail.com
Hi
very obvious self promotion... :))
