fulltilt3r
Electrical Work Price Check
Hi Bro,
Is below electrical quotation for condo project look reasonable? Or anyone got good Electrician to recommend? Thanks in advance.
Price List For Electrical Works
No. Description Unit Price QTY Total
1 Supply labour to run lighting point $38.00 12 $456.00
2 Supply labour to install light $12.00 24 $288.00
3 Supply labour to run fan point $36.00 1 $36.00
4 Supply labour to install fan $50.00 1 $50.00
5 Supply labour to run and install double socket $75.00 6 $450.00
6 Supply labour to run and install single socket $55.00 4 $220.00
7 Supply labour to run and install Telephone socket $50.00 1 $50.00
8 Supply labour to run and install SCV socket $120.00 1 $120.00
9 Supply labour to run and install Cat5E cable for Data Point $80.00 2 $160.00
10 Supply labour to hack and conceal the electrical piping $500.00 1 $500.00
for whole house
Grand Total: $2,480.00
Hi, can pm me your eletrician's contact? Thanks!
Hi Bro,
for whole house
Hi Lim Hoe,
Can you give me the contact of your electrician? And let me know if he is reliable and his workmanship? My email is stevenclh@yahoo.com
Hi I got my price quoted
downlight point - $35
install light -$8
ceiling fan point - $40
13amp single point - $35
13amp Double - $50
aircon point - $60
SCV $60
heater $60
whole house I spend around $2600
Hi Wang Wang, can you send your electrician's contact to my email : stevenclh@yahoo.com
Got this from my contractor for condo for replacement of socket and installation work. Is this reasonable ?
a. Light point Per item $ 45.00
b. Change of casing socket Per item $ 25.00
c. Conceal new socket Per item $ 95.00
d. Change of SCV socket Per item $ 35.00
e. Change of water heater socket Per item $ 45.00
f. Installation of fan Per item $ 180.00
g. Installation of light bulb Per item $ 15.00
Hi all, I have a noob question that I would like to ask. Would appreciate any inputs for clarification. I want to change my existing switch and power socket since the existing ones and yellow with age. How will I be quoted for the work and parts supplied ?
Would I be quoted for example based on the following prices for each socket replaced, or would it be at a cheaper rate ? Thanks in advance to anyone who can provide me with any inputs to clarify on this part.
2. Single Socket - $48
3. Double Socket - $60
That is expensive..
I suggest you go choo chiang market buy all the sockets and replace themselves, is not difficult at all!
REMOVED LINK
This is what my electrician quote to me
1. Lighting Points - $30
4. Instant Heater Installation - $50
5. Hood/Hob/Oven Point - $80
6. Telephone Point - $50
7. SCV Point - $90
8. SCV/Data/Power Loose Wire Extension for TV Console - $25
9. Data Point - $90 cat 5E
10. Downlight Installation - $10
11. Ceiling Light Installation - $20
12. Wall Fan Installation - $20
13. Ceiling Fan Installation - $25
14. New distributions box ---$200
15. Install eubig socket track ---$70
Hi Udyr,
Can pm me the electrician contact?
tks so much.
Electrical Re-Wiring Works
1 13amp single powerpoint @ $50
2 13amp double powerpoint @ $60
3 15amp air-con point @ $90
4 20amp heater point @ $90
5 20amp oven point @ $60
6 Cooker hood point @ $40
7 Tel point @ $45
8 TV ariel point @ $90
9 Ceiling fan & lighting point @ $28
10 Installation of ceiling light/PLC light @ $10
11 Installation of ceiling fan/hanging light @ $60
12 Distribution Board @ $300
My contractor quoted $45 per light point (including switch) and $60 per electrical socket point. My total quote for whole house (5 room flat) was $2230.
Hi Bro,
for whole house
Hi Bro, Can you PM me yr contractor ?
Hi All, I got a contractor for Condo electrical works. Please advise is the price reasonable?
1) 13amp Single power point = $55
2) 13amp Double power point = $65
3) Lighting point = $35
4) Telephone point = $55
5) Cat 6 data point = $120
6) SCV point = $120
7) Lighting Installation = $10
