Need a quote for the following:
1)    ME or MHI, System 3 and System 4
2)    1/2" armaflex(Class0)insulation, 22SWG copper piping, keystone cable, 16mm drainage pipe
3)    Remove old aircon compressor/ fan coil x 3/ copper piping/ water piping
4)    May need to increase aircon trunking due to change in aircon pipe thickness
  • Replies 1.1k
  • Views 187k
  • AirconBestValue
    AirconBestValue
  • AirconBestValue
    AirconBestValue
  • AirconBestValue
    AirconBestValue
Posted Images
22 hours ago, lipton said:
Hi there,
can you quote for Panasonic CU-XS9RKZ?
thank you.
Regards,
Michelle
20 hours ago, jasonleeck said:
Regards,
Michelle
Dear all Renotalk Bro & Sis,
Warmest Regards,
Michelle
3 hours ago, AirconBestValue said:
Regards,
Michelle
Hi Michelle,
Sorry I forgot to indicate earlier, Panasonic CU-XS9RKZ is for system 1. I think you quoted me for system 3.
My BTO HDB 4 room new house is doing renovation now. Pls send me quote (best price) for the following:
1.) Mitsubishi StarMex System-4 (5 ticks model).
2.) HDB.
3.) Cooling Capacity:
option a: 3 x 9K BTU / 1 x 18K BTU
option b: 3 x 9K BTU / 1 x 24K BTU
Kindly include GST, installation, 1/2" Armaflex class "0" insulation, G22 copper pipe, 16mm drainage, warranty (parts and installation), etc....
Thank you.
I would like to replace the single-split unit for my master bedroom.
Pls quote:
1) Mitsubitshi Starmex 12k btu with 1.5hp compressor
2) Panasonic 12k btu with 1.5hp compressor
3) Fujitsu 12k btu with 1.5hp compressor
No need to change piping.
Thank you.
I would like to get a quote for Panasonic or Mitsubishi system 2 for my 3 room hdb.
Need to install bracket
New installation.
2.) HDB.
Thank you.
Regards,
Michelle
On 3/30/2016 at 2:26 PM, volk said:
Pls quote:
Thank you.
Regards,
Michelle
New installation.
Regards,
Michelle
Warmest Regards,
Michelle
Kindly quote for ME Inverter System 3 for HDB:
- Compressor is MXY-3A28VA
- Cooling Capacity:
  • 2 x 9K BTU + 1 x 12K BTU
  • 1 x 9K BTU + 2 x 12K BTU
- Kindly include GST, standard installation specification, material upgrade option, warranty etc...
- Also require to remove old air-con compressor/ fan coil x 3/ copper piping/ water piping.
Thank You!
Hi Michelle,
Can i request for the following quotation for (Please include breakdown for each item):
1.   ME or MHI
2.  2 x 9K BTU + 1 x 12K BTU or 3 x 9K BTU
3.  1/2" armaflex(Class0)insulation, 22SWG copper piping, keystone cable, 16mm drainage pipe (Do let us know the quote as well for standard package used if we do not request for this)
4. Housing type is 4rm HDB BTO (no need for removal of old items)
Warmest Regards,
DL
I need a quote for 5 tick System 2 Inverter and 5 tick System 3 Inverter
Mitsubishi preferably. Suggest alternatives.
System 2: 1 x 18K BTU + 1 x 9K BTU
System 3: 1 x 12K BTU + 2 x 9K BTU
1/2" armaflex insulation, G22 copper piping
Disposal of existing units, piping etc.
