5rm resale flat - is my quotation reasonable?
Would appreciate it if you guys can let me know if the below quotation is reasonable.
We are basically hacking away everything in our resale flat. (all the floor tiles, wall tiles and kitchen cabinets)
Dismantle Works:
Dismantle existing kitchen cabinet   $      380.00
Hack off existing kitchen floor tiles   $      700.00
Hack off existing concrete base , washing machine and fridge base with tiles   $      200.00
Hack off existing 2 toilet wall and floor tiles   $   2,400.00
Dismatle existing toilet accessior ,pedestal pan and basin   $      150.00
To hack off existing floor tiles to Living ,dining ,and three bedroom   $   1,580.00
Dismantle 3 bedroom door and door frame   $      210.00
Hack off existing M/Steel door frame at two toilet   $      180.00
Demolished  Wall And Construct : ( PE Fee Are Not Include )
Bedroom 3 entrance wall to be demolished   $      350.00
To construct wall at bedroom 3,and Linter c/w plastering both side   $      480.00
Bedroom 2 entrance wall to be demolished   $      380.00
To construct wall at bedroom 2,and Linter c/w plastering both side   $      580.00
Bedroom 1 entrance wall to be demolished   $      350.00
To construct wall at bedroom 1,and Linter c/w plastering both side   $      580.00
To construct wall between Bedroom1 and toilet c/w Linter and plastering   $      480.00
Living ,Dining And 3 bedroom Floor Tiles: ( PC Rate 3.0 )
Homogenouse tiles ( 600 x 600 )mm to Living ,and Dining floor area   $   3,580.00
Homogenouse tiles skirting to Living and dining room  $      580.00
Supply chamical cement and sand to screeding 3 bedroom floors   $   2,800.00
Vinyl flooring to 3 bedroom ( with-out skirting )  (Size: 150 x 900 )mm  $   2,800.00
Kitchen Area: PC Rate $3.00
Plastering wall with chemical sand and cement to kitchen wall  c/w painting
( Behind cabinet no plaster )  $   1,950.00
Nippon paint to paint kitchen wall 2 coat of clour and 1 coat of sealer   $      600.00
Homogenouse tiles to kitchen floor   $   1,480.00
Waterproofing to kitchen floor   $      250.00
To construct cabinet base with tiles on side 50mm H   $      280.00
To construct washing machine base and fridge base with tiles   $      450.00
Supply labour to install kitchen sink ,tap and in/outlet pipe ( Cold pipe only )  $      220.00
Supply and install kitchen backsplash with tempered glass at ( Sink & Stove
 Area) top and bottom cabinet ( 3650 x 650 x 5 )mm  $      780.00
To construct concrete slab to kitchen sink and hollow block support c/w lay
tiles finished ( 1500 x 600 x 870 )mm  $      780.00
Master Toilet :
Ceramic tiles to toilet wall ( PC Rate $2.3)  $   2,380.00
Homogenouse tiles to toilet floor   $      850.00
Waterproofing to master toilet  floor   $      250.00
Supply and install shower kerb with floor tiles   $      220.00
Toilet entrance kerb to lay floor tiles   $      120.00
 To construct hollow block wall with linter (2200 x 2650 x65 )mm  $      650.00
Supply and install Fix tempered glass at shower area  (1800 x 900 )mm  $      380.00
Supply & install hanging sliding door with sandblast tempered glass c/w pelmet   $      850.00
Common Toilet :
Waterproofing to common toilet  floor   $      250.00
Supply and install Aluminium Bi-fold door   $      250.00
False Ceiling Work:
False ceiling to Living and dining room   (7100 x 700 )+( 1400x1100 )mm  $      580.00
Supply and install L boxes c/w cove light (1 side) ( 500x14200)+(500x7000)mm  $      980.00
Bedroom Door :
Supply and install 2 nos. Design Door and door frame c/w varnishing    $   1,360.00
Plumbing Works: (Materials not included except stainless steel pipe)
Supply and install cold stainless steel  pipe to kitchen and two toilet  $      880.00
Supply and install 1 nos.of Storage Heater    $      200.00
Installation of 2 basin with tap  $      180.00
Installation of 2 spray tap  $      100.00
Washing machine with outlet pvc pipe  $      120.00
Install 2 set of mixer with hand shower   $      180.00
Installation of toilet accessories to two toilet  $      160.00
Supply labour to install 2 nos.of pedestal pan   $      220.00
Cabinet Works:
a: Supply and install top and bottom cabinet at kitchen sink and stove area
    ( 5600 x 600 x 2650 )  $   4,150.00
b: Supply and install stainless steel dish rack 1 lot  $      150.00
c: Install 1set of Alum glass door with gas spring  $      380.00
d: Supply and install 1 set blum drawer   $      350.00
e: Supply and install Granite surface to kitchen cabinet top c/w skirting  (India)  $   1,650.00
a: Supply and install Wall-in wardrobe c/w plywood backing ( 6540 x 2650 )mm  $   4,750.00
b: Supply and install 2 nos.of hanging sliding door at wardrobe entrance   $   1,160.00
Painting Work:
ICI or Nippon paint to paint whole unit wall and ceiling ( 3 colour )  $   1,850.00
Miscellaneous
To provide labour to clear haulage and debris fee  $   1,350.00
Supply labour for chemical wash and cleaning whole house  $      450.00
Electrical Work:
Reinstall wiring  Estimate  $3500
Each light / Fan point                                              $65
Each light installation                                              $12
Each Hanging light installation                                $90
Each hanging fan installation                                  $90
Each single power pt                                               $65
Each double pwr pt                                                 $80
Each SCV                                                               $110
Each Tel pt                                                             $60
Each Isolator 20A                                                   $220
Each Heater pt                                                       $150
Each cat 6 Data point                                             $180
Base on demolish, electrical and painting works u quoted here, I think there are a lot of rooms for negotiations.
Agree with that. Some prices are ok. A few are are just a tad higher. Just ask for a overall discount before signing. They usually will accede to such requests.
ur quote looks expensive.. Some areas like plumbling, painting, electrical, carpentry too.. Maybe u can compare around. Most importantly is u feel comfortable n price within ur budget that's good already. All d best!
Hello fellow members of Renotalk. Sorry for hijaking your thread. I tried to create my own thread but there seemed to be some error. Moderator, If you could move this post to a new thread please do so. Thanks!
I am particularly new to this scene as this is my first time renovating my house after 20 years. Was given a quote by an ID/Contractor. Could you gurus please take a look to see if it is acceptable? I decided to renovate my kitchen and 2 toilets. The quotations are as such below:
No
Description Amount
A.
a.)
1.
2.
3.
4.
5.
6.
b.)
1.
2.
3.
4.
5.
c.)
1.
2.
3.
4.
B.
a.)
1.
2.
3.
4.
5.
C.
1.
2.
D.
a.)
1.
2.
3.
4.
b.)
1.
2.
3.
4.
5.
6.
c.)
1.
2.
3.
4.
5.
6.
E.
1.
2.
3.
4.
5.
F.
1.
G.
1.
H.
1.
I.
1.
J.
1.
2.
3.
4.
5.
6.
7.
MASONRY WORKS
@Kitchen
To supply labour, tools & materials to install waterproofing screeding at kitchen $380
floor and wall area.
To supply labour, tools & materials to top up floor & wall leveling using prepack 3 in 1 mix $700
cement/sand at kitchen flooring.
To supply labour, tools & materials to lay (Size: 300mm x 600mm) heavy duty homogenous $2,150
floor tiles at kitchen floor. (215 sqft.)
To supply labour, tools & materials to lay (Size: 300mmx 600mm) homogenous/ceramic wall $4,850
Tiles at kitchen wall. (approx. wall area 485 sqft.)
To supply labour, tools & materials to construct kitchen cabinet concrete base at kitchen. $450
@Master Toilet
To supply labour, tools & materials to install waterproofing screeding at master toilet floor $180
and wall area.
To supply labour, tools & materials to top up floor and wall leveling using prepack 3 in 1 $900
cement/sand  at master toilet.
To supply labour, tools & materials to lay (Size: 300mm x 600mm) homogenous floor tiles $1,100
at master toilet. (Approx area 68 sqft.)
To supply labour, tools & materials to lay (Size: 300mm x 600mm) homogenous wall tiles $2,800
at master toilet. (Approx area 280 sqft.)
To supply labour, tools & materials to construct shower kerb at master toilet. $190
-2-
@Common Toilet
To supply labour, tools & materials to install waterproofing screeding at common toilet floor $200
and wall area.
cement/sand  at common toilet.
To supply labour, tools & materials to lay (Size: 300mm x 600mm) homogenous floor tiles $950
at common toilet. (Approx area 55 sqft.)
To supply labour, tools & materials to lay (Size: 300mm x 600mm) homogenous wall tiles $2,600
at common toilet. (Approx area 260 sqft.)
CARPENTRY WORKS
@Kitchen
To supply labour, tools & materials to fabricate & install top hung kitchen cabinet using               $2,805
selected laminated finish c/w swing door panel with abs edging internal carcass using
white pvc panel with adjustable shelf.
(Approx size: L-25.5ft. s D-1 ft. x H-1150mm.)
To supply labour, tools & materials to fabricate & install Bottom kitchen cabinet using $2,420
selected laminated finish c/w swing door & drawer panel with abs edging internal carcass using
(Approx size: L-22 ft. s D-2 ft. x H-830mm.)
To supply labour, tools & materials to fabricate & install tall unit cabinet c/w swing $720
door panel with abs edginginternal carcass using white pvc panel.
(Approx size: L-6 ft. s D-1 ft. x H-1150mm.)
To supply labour, tools & materials to install 4 sets heavy duty soft close drawer $300
track at kitchen cabinet.
To supply labour, tools & materials to fabricate & install suspended vanity cabinet c/w swing $400
door panel  using selected laminated finish at master toilet.
(Approx size: L-3.5 ft. x D- 400mm x H-500mm.)
QUARTZ STONE @KITCHEN
To supply labour, tools & materials to install Quartz stone work top at kitchen cabinet. $2,420
(Approx size: L-22 ft. x D-2 ft. x 20mm height profile.)
To supply labour, tools & materials to install Quartz stone work top at vanity cabinet. $350
At master toilet. (Approx size: L-3.5 ft. x D-2 ft. x 20mm height profile.)
PLUMBING WORKS
@Kitchen
To supply labour, tools & materials to install exposed (cold) stainless steel water inlet piping $680
Work at kitchen sink & washing machine.
To supply labour and tools to install kitchen sink & water tap mixer.                                                 $150
To supply labour and tools & install new 40mm water outlet pvc piping works at kitchen sink $300
and washing machine.
-3-
To supply labour and  tools to install water tap for washing machine. $120
@Master Toilet
To supply labour, tools & materials to install exposed (Hot/Cold) stainless steel water inlet $300
piping work at master toilet.
To supply labour and tools to install wash basin & hot/cold water tap mixer at master toilet. $150
To supply labour and tools & install new 40mm water outlet pvc piping works at wash basin $150
at master toilet.
To supply labour and  tools to install water tap for washing basin at master toilet. $150
To supply labour, and tools to install spray gun c/w stainless steel water piping work c/w on/off $120
Mini vale at master  toilet.
To supply labour, tools & materials to install instant water heater at master toilet. $120
@Common Toilet
piping work at common toilet.
To supply labour and tools to install wash basin & hot/cold water tap mixer at common toilet. $150
To supply labour and  tools to install water tap for wash basin at common toilet. $150
Mini vale at common toilet.
To supply labour, tools & materials to install instant water heater at common toilet. $120
ELECTRICAL WORKS
To supply labour, tools & materials to install new lighting point at kitchen. $120
To supply labour, tools & materials to install new lighting point at common toilet. $120
To supply labour, tools & materials to install new (2 x 13A) double power point x 4 nos. $720
at kitchen
To supply labour, tools & materials to install new cooker hood power point 1 x 20A $120
on/off switch at kitchen.
To supply labour, tools & materials to install new (1 x 20A) water heater power point c/w $190
on/off switch socket at common toilet.
GENARAL CLEANING WORK
To supply labour and tools  to provide acid cleaning to upon completion of all works. $400
PAINTING WORKS
To supply labour, tools & materials to paint kitchen and part of living room cornices $600
ceiling using NIPPON paint finish.
CEILING WORKS
To supply labour, tools & materials to install simple cornices **** room. $400
SHOWER SCREEN
To supply labour, tools & materials to install 10mm thick tempered clear glass shower screen $580
c/w 1 fx and 1 panel swing door panel at master toilet.
PD DOOR
To supply labour, tools & materials to install powder coated Aluminium frame with acrylic             $760
panel PD door  at master & common toilet.
-4-
To supply labour, tools & materials to install powder coated aluminium frame with acrylic             $680
panel PD door  at kitchen entrance.
To supply labour, tools & materials to install new aluminium frame with clear glass                        $180
casement window at master toilet.
casement window at common toilet.
To supply labour, tools & materials to install ceiling fan at bedroom.                                                F.O.C
To supply labour, tools & materials to install ceiling fan **** room.                                           F.O.C
To supply labour, tools & materials to install 1 no. power point **** room.                                F.O.C
        Grand Total Amount $:     $36,125
Please give me your valuable advice. Thanks alot!
