@Ohwowitsmac
Thanks for you reply.
Just to check with you on a few things as my layout is same as yours.
Your masterbedroom is connected to your bedroom 2 right? The door to the original masterbedroom has shifted as well right?
the master bedroom is converted to a walk in wardrobe.
Did the previous owner hack the kitchen wall and move in into the masterbedroom?
Really lovely place you have.
14 hours ago, carkingsheep said:
@Ohwowitsmac
Thanks for the compliments!
1) correct, the MBR is connected to another bedroom. However, I'm not sleeping in the MBR which comes with an en suite. Instead I am sleeping in the other bedroom, the MBR has been converted to my changing room.
2) Yes the door shifted. Technically it's sealed up. And the door moved internally to connect the 2 rooms.
3) No, did not hack the kitchen wall to move into the bedroom. But did hack the wall to open it up.
