HomeSecure is the Singapore distributor for Remsafe products. Visit our website http://homesecure.sg and Facebook Page https://m.facebook.com/HomeSecure-580243588808544/ to read more about our products, or to enquire on prices. Alternatively, email to us at Homesecure.sg@gmail.com.
Do you have active children? Do you want to secure your windows to prevent any accidents? Do you want to enjoy full view without any grille? If the answers are "yes", Remsafe Window Restrictor is the product for your new home. Special pricing with MOQ for group buy for your development.
The Remsafe Window Restrictor is Australian designed and is designed to reduce the risk of falls and accidents associated with unrestricted casemenr windows.
Strength Remsafe window restrictors have been tested to withstand a force of 2485 Newtons (253kg), 10 times greater than the minimum standard required by most building codes and legislation in the world. Comprised of a stainless steel bullet head and tensile steel cable for extra strength and durability, Remsafe is the most affordable and reliable window restrictor available. Quality The Remsafe window restrictor is Australian designed and manufactured at the highest quality control.
The advantages of installing Remsafe Window Restrictors are as follows:
1. Fraction of cost compared to window grille (only 5-10% of the cost of window grille for a typical apartment).
2. By using the keys supplied with each set, Remsafe Restrictor enables the windows to be opened fully when needed, allowing owners to open fully to enjoy the scenery, and closed to the restricted safe distance (recommended to be maximum 10 to 12.5cm).
3. Unlike conventional window locks, the ***** feature eliminates the risk of a window being inadvertently unlocked and unrestricted.
Remsafe window Restrictor are available in black, silver and white. Each set comes with the window Restrictor, universal key (1 key to open all your locks) and installation screws. Installation is simple and can be done by your carpenter, or DIY with a electric hand drill.
The VENLOCK is designed specifically for use on sliding windows. The unique patented design allows for an easy DIY installation in less than 30 seconds, with only one hole required in the window track for fitting, no screws required.
- Ideal for sliding aluminium windows
- Easily installed in just 30 seconds
- Australian owned and designed
- Tested to withstand a force of 1700 Newtons (173kg), greater than 6 times the minimum legislative standard
- No fixing screws required
A safe, simple solution
The Venlock window restrictor's DIY installation method is simple, quick and poses no risk to the integrity of the window frame or glass panel.
Once the Venlock is locked in place at the recommended position of 12.5cm, the window can be opened and closed to that position without the use of a key each and every time. Designed with safety in mind, this unique feature eliminates the risk of the user inadvertently leaving the window unlocked and unsecured.
Discreet and reliable
Less than half the size of conventional window locks for sliding aluminium windows, the Venlock is a small but incredibly strong window restrictor.
The compact design will increase the security and safety of you home, workplace or commercial premises without compromising the overall appearance of you window.
Installation instructions:
Window sill height should be no less than 13mm
Place drilling jig on window sill at the end of the window frame
Using a sharp pencil mark the hole position on the window sill
Drill hole using a 6.5mm / 1/4 inch drill piece
Place window lock on the sill and push to lock
Installation Video
https://www.dropbox.com/s/kui1g4y1mcpaasr/Remsafe Venlock_Instruction Video_v2.mp4?dl=0
Features:
Easy 30 second DIY installation
Fits to sliding aluminium windows
Unique patented design
Push to lock/key to unlock
Keyed alike
Black colour standard
