andrew77 0 Report post Posted July 11, 2007 How can I plan the number of points and lighting required?I heard from my friends that every corner should have one plug.Any tips of website that i refer to on how the lighting and points could be designed? Thanks Share this post Link to post Share on other sites
MaCe 3 Report post Posted July 11, 2007 How can I plan the number of points and lighting required?I heard from my friends that every corner should have one plug.Any tips of website that i refer to on how the lighting and points could be designed? Thanksyour contractor can help you plan(provided he is honest) or else you gonna have a lot of powerpoints all over your house.You need to plan where your TV is, where you want to put your washingmachine,fridge,microwave oven...etcfor tv side, we put 2x double sockets. the rest 1x doublesocket.For corners, if you planned carefully you will save some money cos not all the corners in house will be used.some corners you might want to put cabinets/tables/etcthen, for lights, depending on how big your place is - is 1 ceiling light enough to bright up the whole room?or how many lights in the Lbox? or if you have false ceiling - a lot of down lights is needed. Share this post Link to post Share on other sites
