kst
Help : Aircon Planning
Hi Warrior88,
I got the following for the bedrooms :
MASTER BEDROOM
BTU = 9275 (2.71 kW)
BEDROOM 2
BTU = 8327 (2.43 kW)
BEDROOM 3
Hence I go for MSXY-GA13VA (3.5 kW) for Master Bedroom, 2 x MSXY-GA10VA (2.5 kW)
for Bedroom 2 and 3.
I understand Bedroom 2 & 3 might not be cooling enough but from experience, I normally
set temperature to 26C lowest since these 2 rooms are my kids' rooms and we normally
don't make it too cold. Hence, I doubt there will be cooling problem.
I might be wrong here but worse case, I can still opt for 3 x MSXY-GA13VA (3.5 kW). Will
talk to the aircon seller and see what they recommend.
Hi Kst,
You might just want to consider using just one condenser MXY-4A28VA or MXY-4A38VA , both able to support 10+10+13+26 . Most of us don't turn on all the fan-coil , looking at your case I believe you might only use 3 fan-coils together, however, I think MXY-4A38VA meet your requirement.
the installers must hv integrity and not cut corners when installing. to avoid future leaking problm, owner must be around when they install the piping and most imptly, be there to witness the whole process of pressurization.
Leen, thanks for sharing all your aircon links! what must we look out for during the pressurization process?
these are the quotes i was given for toshiba.
toshiba system 3 inverter (got this combination as i need to cool a big hall and MBR) and i am installing 2 sets of system 3 (if i do decide on system 3)
outdoor unit: RAS-3M23YACV - 24,000BTU/Hr x 1 unit
indoor unit: a) RAS-M10NKCV - 9,000BTU/Hr x 2 unit +
b) RAS-M13NKCV - 12,000BTU/Hr x 1 unit
prices do not include bracket coz i hv concrete aircon ledge:
a) h@ng ta - S$2,780
b) Best tech - S$2,653.60
c) mega - S$2,550.00
d) hong huat - S$3,103
e) federal - S$2,398.00
toshiba system 4 inverter (if i get this combination, i would need to get 1 more single split system coz not enough for my hm)
outdoor unit: RAS-4M30YACV - 30,000 - 34,000BTU/Hr x 1 unit
indoor unit: a) RAS-M10NKCV - 9,000BTU/Hr x 3 unit +
a) h@ng ta - S$3,730
b) Best tech - S$3,456.10
c) mega - S$3,400
d) hong huat - S$3,531
e) federal - S$3,400
if bracket is required, the prices are:
a) h@ng ta - S$120
b) Best tech - S$150
c) mega - S$120
d) hong huat - S$100
e) federal - never state
all piping and insulation base on manufacturer's spec. basically its either, armaflex, k-flex, thermaflex, totaline insulation etc.
cu piping as per manufacturer's specs.
piping and cabling all in pvc trunking.
these are the quotes i was given for mitsubishi.
mitsubishi system 3 inverter (got this combination as i need to cool a big hall and MBR) and i am installing 2 sets of system 3 (if i do decide on system 3)
outdoor unit: MXY-3A28VA - 30,000BTU/Hr x 1 unit
indoor unit: a) MSXY-GA10 - 9,000BTU/Hr x 2 unit +
b) MSXY-GA13VA - 12,000BTU/Hr x 1 unit
a) h@ng ta - (mitsubishi electric)S$2,900 / (mitsubishi heavy) S$2,680
c) hong huat - S$2,950
d) all best - S$2,731
e) best denki - S$3,299.00
f) double-h aircond - 3,150.00
g) golden harvest
h) systematic airconditioning - S$3,100
mitsubishi system 4 inverter (if i get this combination, i would need to get 1 more single split system coz not enough for my hm)
outdoor unit: MXY-4A28VA - 30,000BTU/Hr x 1 unit
indoor unit: a) MSXY-GA10 - 9,000BTU/Hr x 3 unit +
b) hong huat - S$3,650
a) h@ng ta - S$120
b) hong huat - S$100
c) all best - S$150
d) best denki - S$110
e) systematic airconditioning - S$100
hi, i got a list of checklist but its kinda long to state here.
