An Chuan (couple & Customary)
Hi Mr Chong,
Need to check with you the following:
1) Bedframe
2) Mattress
3) Boster/pillow
4) Bedsheet
Which is important? I've not done my customary yet. Investing a good bed frame with normal (2),(3)&(4). Do you suggest keep the bedframe for Actual wedding date for an chuan & change all else?
Also, there isn't a need to an chuan when a couple move in to a new house before their customary rite? Jus need to take not of move in date will do?
Edited by HOME2BE
Hi Mr Chong,
1) Bedframe
2) Mattress
3) Boster/pillow
4) Bedsheet
Hello
As this question is about FS, none of the above options are important. If this is on comfort and health, then all are equally important.
Most imporatant is that you need to find a good place to place your bed.
You should get a move-in date before you an chuan (or do it on the same date). If you have already placed the bedframe, then select a date to an chuan the mattress.
Hello
Thanks. So an chuan is not really matter if its a used bedframe. I'll just replace a new mattress wil do.
