Removal Of False Ceiling
hi once again....likewise HDB guide do not mentioned abt removal of false ceiling.....since no permit is require to put up ceiling...can i presume i can remove all my false ceiling?
as long as it's not something ORIGINALLY there when hdb handed over the new flat, it can be removed
yupz.
Would it be real messy to change L Box? and how long would they take?
change? change simi? or do you mean REMOVE?
remove of cos messy lor...
Well...do some alterations to current lbox? possible?
depends on what you wanna alter....certain things cant be altered.
if just wanna add lights then the mess will be at it's minimum.
i want to remove the false ceiling so i have higher ceiling.
removal is easy but messy as mentioned by some of you.
ceiling will be coated with cement like coumpoud, including the well..
to remove the existing lighting is probably the hardest....
then def will be messy - removing the whole false ceiling + repainting + patching up the holes..
