kunning
Glass Door For Kitchen
Can anyone advise if it's appropriate to install a glass door for the kitchen entrance? I thought this may allow more light into the house, but not sure about the fengshui part.
thanks in advance!
kunning
thanks in advance!
kunning
Glass door has nothing to do with fengshui. Most important is your stove and sink position.
only difference is a OPEN concept kitchen and a kitchen with door or entrance(close, conventional)
nothing to do with the material of the door.
thanks vowsh! Glad to hear that.
Can you share more on the positioning of stove & sink? Read somewhere that they must be adjacent to each other.
hi, I'm also curious on the stove and sink part.
Read somewhere that as long not facing each other
is ok. side by side or 90 degrees to each other should
be ok rite? any comments anyone?
The position of the stove and sink really depends on the occupiers' bazi.
East and West grp of people will need to position your stove/sink according to enhance your wealth.
Some fsm may says kitchen is for wife while living rm is for hushand. Lucky me and my wife belong to the East grp so our kitchen suits both of us.
By book, east grp people needs to siam west direction and vice versa. I.e. position stove in the west direction. The layout can be odd for some, if L L must put stove in the east direction. You can put a stone hu-ru at the top drawer tier and a bronze item at the bottom tier. At least minimize the bad effect.
If have a build-in oven, try not to put under the washin basin as oven mean gold/metal. Wafer corrode metal.
Lastly to make the kitchen bright by avoiding darker tone laminate. Again if die die want to use dark laminate, u can choose glossy surface type or use more glass backing.
Hope this info helps.
Can the sink and stove be on the same side of the table top? Also can the oven be below the stove?
can.
