Why My Macbook Got Heat Up Immediately I Jus Power On It?
:wub::wub:
as above, any macbook user have this problem, duno wat gone wrong recently den i have such problem
their service centre is useless la, nowsaday so scare to send to service centre....
you know about edison case la....
backup your data, lock your account and create a new account with no access to the files for them to do servicing :wub:
:dancingqueen: you also have those..... :wub::wub:
backup your data, lock your account and create a new account with no access to the files for them to do servicing :P
they are good in tat mah. no matter wat u do they sure know how to unlock one.
:P you also have those..... :dancingqueen::lol:
:wub::wub:
wait they take my photo & do someting with photoshop & load on web la,
if you really worried, then transfer your files to a external HDD
do a clean reload of the OS, should be safer liao
if you really really really worried, go to disk utility under applications
find the one that overwrite your HD 37 times one
sure your files won't leak liao
but it'll take about a day to run :bangwall::)
me sent my one to the AMK one, no problem lah
we not celebrity mah :yamseng:
what is the cause of macbook to heat up immediately after power on ?
isit background there software running?
actually macbook and macbook pro had heat problems coz of the heat sink location
the vent for heat dissipation is in between the keyboard and the screen
i know that the problem can be alleviated to a certain degree after changing the motherboard, but the heat problem will still be there
so the thing is if the heat problem wasn't there until recently
or after you updated your software
then better to send it in
did you buy applecare?
Do you feel the fan working? any hot air blowing out at the rear base hinge joining the LCD display?
finally i found the root cause at the monitor activity.
its the printer job take up alot of cpu space tat cus the fan noise so loud . gosh finally..
thanks!:dancingqueen:
off-topic:
applecare (for the laptop/desktop) is a must even though it seem ridiculously expensive (without discounts).
i have always utilize it to the max for my ibook and imac. hopefully, it won't be needed on my macbook pro (although i seriously doubt it). the only occasions where it didn't pay off were for the ipods.
Edited by floppy
i'm quite sure you'll find it useful
better have it and not need it then need it and not have it :notti:
