No Horse Run
Need Mr Chong Advise
Hi Mr Chong,
Just to add on, my house sitting is 坐癸向丁 198 degree.
View from my door to the left
View from my door to the right
Do I miss out any information which you require? Do let me know.
Thank you.
Hi Mr Chong,
Thank you.
Hello
Yes, follow my pinned instructions and give me a few more readings. Also give me DOB+time. One pic from corridor looking below block. One pic behind, should be taking from mbr horizontally.
BTW, I thought you said there's a lift in front of your door?
Hi Mr Chong,
View from my front corridor downwards:
View from my MBR:
Compass reading:
at front door: 205 degree
3 steps beind front door: 194 degree
**** hall window: 207 degree
centre of the living hall: 196 degree
Thank you.
Hi Mr Chong,
Compass reading:
Thank you.
Hello
Still short of DOB
Hi Mr Chong,
My DOB IS 丙午年 癸巳月 甲戌日
Thank you.
Regards.
Hello
Give me the exact time. I calculate my way. PM me.
Hi Mr Chong,
Already PM you the time.
Thank you.
Hello
Ok, got your time.
If you've move-in already with furnitures, it will be good that you place some furnitures (sofa will be good) along the wall of living adjacent to the toilet. For your case don't put too near towards the main door.
It would be better that you sleep in the room beside the main door. Headboard in the direction towards main door direction. I want to try sleeping in MBR, then there will be some sacrifice to make. Sleep still same with head facing main door direction. Try not to put bed at far right from room door.
Put 2 plants opposite your main door along the corridor (on the right side looking out) Plants should be tall.
Go out to your corridor and take one more reading.
The rest of the furniture arrangements, you can put down on the floor plan and I'll advise you again.
Hi Mr Chong,
From my floor plan, my kitchen is on the right hand side of my living room, my main door when I walk into my house.
So from your reply, i am confused you advised me to sleep in the room beside the main door? You mean to sleep in the room beside the master bedroom?
Anyway, I am sleeping in the master bedroom, headboard facing east.
Please correct me if I am wrong.
Thank you.
Hi Mr Chong,
Thank you.
Hello
Oh I see. Your floor plan didn't indicate 'kitchen', stove, etc. I thought it was another room. Too bad, other wise it will suit you to sleep bettter.
Sonce that's the case, use back the MBR and stay away from the far right. Don't worry about window. See if can get bed headset to face south.
Hi Mr Chong,
1) I went out the house to take another reading is 196 degree
2) Please enlighten me why I need to put two tall plants opposite my main door?
3) I am sleeping in the far right of my master bedroom because I was advised to sleep in the 艮卦 因为我是西四命
请指教为何我的床头应向南?
谢谢!
Hi Mr Chong,
Please find below some of the essential furniture in the house:
In the master bedroom, on my left hand side is the built in cabinet.
Await your advise.
Thank you.
Regards.
Hi Mr Chong,
请指教为何我的床头应向南?
谢谢!
Hello
This is to manupulate the flow of Qi outside your door.
Group west and east method is a simple stepping stone to learn FS. It lacks of accuracy.
Hi Mr Chong,
1) I have attached my furniture layout in the previous post. So if i placed my bed head facing south. There will be no "solid support" behind me. Currently, my headboard is facing east.
2) I have read some books, say it is important to avoid "本命的绝命方“ 和 “宅的要煞“ so for my case my house is 坎宅 so i must avoid sitting or sleeping at “辰戌” 山。
Please advise.
Thank you.
