If The Toilet Bowl Flushing Is Weak, What Can U Do About It?
WC design is the one that determines the flushing power.
Is there an adjustable mechanism within the cistern? Raise it to bring up the amount of water level stored when at full capacity.
i got different problem. after flushing, it takes a long time for the water reserve to be filled up before i can flush again. I only encountered this problem recently. Did not had this problem before
A leak? Do check all your hoses and parts, we had this problem before, what we did was to seal up the side air outlet (kindda hard to explain - you have that?) at the side of the cistern and the situation did improved. I suspect it has something to do with pressure.. though I'm not really sure myself :sport-smiley-018:
