Need Help On Reno Quote: 4 Room Type 3a
HI all,
please advise if the quotation is reasonable. thank you very much
Demolish Work
1) hacking btw kitchen and living room - (subject to P.E endorsement $500) = $360
2) Disposal of reno debris = FOC
Mansory works
3) To make a good wall btw kitchen and living = $360
4) to construct cement sitiing with both side support and lay tiles finish at master toilet = $280
5) to constrict 50mm cabinet base at kitchen =$270
6) to supply and labour to apply enfoxy flooring **** and passageway = $720
Miscellaneous/General services
7) to install 10mm frosted tempered glass swing door w/lock at master toilet and common toilet =$1100
8) install 10mm tempered glass shower screen at master =$460
9) install laminated flooring in 3 bedroom with skirting = $1720
10) ICI emulsion paint on all doors, rooms, celings...walls =$1150
11)laying of cardboard protection =$180
12) chemical wash on toilet and kitchen and general cleaning upon completion = FOC
Carpentry works
Kitchen
13) to design and fabricate 30ft kitchen cabinet with ABS triming in laminated finish = $3000
14)install 12.5ft stealess steel back btw top and bottom cab = $700
15)install 17.5ft solid surface c/w profile = $1320
16) install 8ft solid surface top c/w wooden support for bar counter = $960
total:$11,900 after discount
Do be careful regarding these prices, example. after demolishing the wall do they patch up the wall. The kitchen cabinets are they using solid ply, even they are using solid ply ask them whether they are using China or Indonesia.
If you need a 2nd opinion. pm me I will be able to recommend a honest ID for you.
Regards.
HI all,
Demolish Work
Mansory works
Carpentry works
Kitchen
HI all,
Demolish Work
Mansory works
Don't u need the base for washing machine and fridge
are you talking abt epoxy flooring
confirm the brand and years of warranty
U are talking abt corrugated paper rite. Very Cheap only mah. A big roll only cost $10-$20
Carpentry works
Kitchen
Seems to me that u won't be doing hacking of tiles etc and you got no existing kitchen cabinet to demolish. But Don't they need to redo the power point and pipings. Inlet and outlet.
Yup. I do not need to hack the tiles and kitchen cabinet to demolish as this is a new flat and the floor is raw. they will advise on the powerpoint and pipping again
The base is for kitchen cabinet, not washing machine or fridge.
I am doing the expoxy flooring
flooring: they did'nt say the brand...2 yrs waranty
not sure about the cardboard protection....
thanks Alan, please advise what should i ask next to clarify..is the quotation reasonable? do you any ID/contractor to recommend
The quotation consider reasonable. But u sure on doing eproxy flooring? Check what laminate flooring they providing u, u don't want to change flooring after 2 yrs right? :)
Yup pretty sure on doing eproxy flooring. y?
you mean the brand of the laminating flooring?
do you have any ID to recommend? Thanks
Oh ok, so u do see the sample of eproxy flooring, do the ID give warranty on that?
Yes, asking for the brand of the laminate they going to use. 2 year warranty is too short.
Sorry, I do not have any ID to recommend although my friend is presently working as an ID. Had not seen his work yet. :) I didn't engage any ID to do my house reno. :)
Hav'ent seen yet..the brand of the flooring is heavy duty "firmaflor: how long the warranty should i be looking at?
I cut down some stuff and now they charge me for plumping
installation of kitchen tap and sink - $120
installation of 2 water heater or storage heater $240
installation of bathroom accessories - $150
the whole reno still cost about $10k....
thought plumping is FOC as my flat is new...do i need all these plumping
On the market now. you can get laminate floorboards which give life time warranty. If you need an ID pm me.
Heavy duty "firmaflor" or not u also can't spot the different. Is not a very popular selling brand in Singapore, that why it cheap. Maybe because it does not provide longer warranty as most brand was like min.15yrs to lifetime warranty.
Plumping is needed unless u want to do the installation yourself. :good:
For everything to do at the cost of $10K is consider cheap already. Good luck to u and happy reno. :yamseng:
Thanks for your advise.
