Is This Quotation Ok For 4ng 92sqm?
hi all
can assist to look at the quotation n give any comments. tks for all your advise in advance
http://www.renotalk.com/forum/index.php?showtopic=22016
1 PROFESSIONAL SERVICE
A To provide Interior design services with proposed layout plan FOC
B To provide Perspective drawings on carpentry works upon confirmation FOC
C Material & color scheme proposals FOC
D 2 year Warranty for workmanship FOC
E Final inspection on site FOC
2 DEMOLITION
A To demolish existing floor tiles :- Lump sum $2,400.00
2 Baths
Living
B To demolish existing wall tiles :- Lump sum Inclusive
2 Baths
Kitchen
C To demolish existing sanitary ware :- Lump sum FOC
2 Baths
D To demolish existing cabinet :- Lump sum $200.00
Kitchen
E To demolish existing door frame :- Lump sum $80.00
Store
F To demolish existing wall :-
Store Lump sum $300.00
Between Master Bedroom & Bedroom 2 Lump sum $400.00
Master Bath ( new doorway ) Lump sum $100.00
* Subject to HDB approval
2 WET WORK
A To supply and lay water proofing :- Lump sum $300.00
2 Baths
Kitchen
DESCRIPTION QTY AMOUNT
B To make good due to demolish wall :-
Store Lump sum $120.00
Master Bedroom Lump sum $150.00
Master Bath ( new doorway ) Lump sum $80.00
C To convert squating pan to sitting WC :- Lump sum $200.00
Common Bath
D To construct cabinet base w/ front tiles :- Lump sum $200.00
Kitchen
E To construct washing machine base w/ fully tiles :- Lump sum $80.00
Kitchen
F To construct shower kerb w/ fully tiles :- Lump sum $80.00
Master Bath
G To seal existing door way w/ hollow block :-
Master Bath Lump sum $250.00
Master Bedroom Lump sum $250.00
3 FLOOR
A To supply and lay polished homogeneous tiles w/ skirting :- Lump sum $3,500.00
Size : 600mm x 600mm
* ( Based on tiles retailing at up to $2.50 psf at preferred suppliers only )
Living
3 Bedrooms
B To supply and lay matt homogeneous floor tiles :-
Size : 300mm x 300mm
2 Baths Lump sum $800.00
Kitchen Lump sum $1,200.00
4 WALL
A To supply and lay ceramic wall tiles:-
*(Based on tiles retailing at up to $2.40/sqft at preferred suppliers only)
2 Baths Lump sum $2,000.00
Kitchen Lump sum $2,000.00
B To construct gypsum board partition:- (w/ tiles skirting)
New Store Lump sum $450.00
Between Master Bedroom & Bedroom 2 Lump sum $800.00
Master Bedroom (vanity area) Lump sum $300.00
5 DOOR
A To supply and install aluminium bi-fold door :- Lump sum $400.00
2 Bedrooms
B To supply and install Classic door w/ wooden door frame :-
New Store Lump sum $300.00
Bedroom 2 Lump sum $300.00
C To supply and install Classic door (w/standard lock) :- Lump sum $300.00
Master Bedroom
Bedroom 3
D To supply and install 10mm tempered clear glass shower screen :-
( Swing door + fixed glass panel )
Master Bath Lump sum 360.00
6 WINDOW
A To supply and install Aluminum casement window :- (silver) Lump sum $1,740.00
Whole house except 2 bath (Ht1200)
B To supply and install Aluminum window grilles:- (silver) Lump sum $700.00
7 PLUMIBING
A To supply and install stainless steel cold piping :- Lump sum $580.00
2 Baths
Kitchen
B To install WC :- Lump sum $160.00
2 Baths
C To install instant heater :- Lump sum $100.00
2 Baths
D To install basin & tap :- Lump sum $100.00
2 Baths
E To install sink & tap :- (Inclusive of inlet & outlet) Lump sum $60.00
Kitchen
8 ELECTRICAL
A 4 Room Electrical Re-Wiring Package Lump sum $2,100.00
- 10 nos. light wiring & point
- 2 nos water heater point
- 3 nos TV point
- 1 no. air-con point
- 3 nos tel. point
- 1 no. MCB board
- Installation of 10 nos. light
- 9 nos. double point
- 3 nos. single point
- 2 sets boarding earth
9 PAINTING WORK
A To furnish wall with Nippon Easywash Lump sum $1,200.00
whole house 6 colours inclusive of white
To paint all pipings and door frame Lump sum Inclusive
10 CARPENTRY
All works are in laminated finish on solid plywood unless otherwise stated
Exclusive of all electrical and lighting works
A KITCHEN
a Design, fabricate and install Designers' laminate-finished 26 ft $2,340.00
Kitchen Cabinet Including :
* Laminated doors with ABS trim.
* Internal PVC white finish
* Stainless Steel Dish Rack and Drainer.
* Imported Designer's Handles or chamfer edging handle
* 1 no. of Cutlery Tray
b To supply and install Solid surface top 13 ft $910.00
c To supply and install extra laminate backing Lump sum $100.00
d To box-up sewage piping in laminate finish cabinet L750mm $550.00
B FOYER
a Design and install Shoe cabinet Lump sum $800.00
Full ht cabinet w/ casement door ABS trimmed
White PVC interior
Loose adjustable shelving
Size: 1200L x 400D x 2600Ht
C MASTER BEDROOM
a Design and install Wardrobe Lump sum $1,100.00
Casement laminated door
White pvc internal finish
Stainless steel hanging rods
Standard drawers with locks
1ft L x 4ft Ht mirror behind casement door
Size: 1600L x 600D x 2600Ht
b Design and install Wardrobe Lump sum $1,200.00
Sliding laminated door
c Design and install Vanity cabinet Lump sum $750.00
Wall mirror w/ suspended cabinet
Solid surface top exclusive basin
Size: 800L x 500D x 1800Ht
D BEDROOM 2
a Design and install Wardrobe Lump sum $1,000.00
Size: 1500L x 600D x 2600Ht
E BEDROOM 3
11 MISCELLANEOUS
A Acid washing for the new flooring Lump sum FOC
B General cleaning for whole house Lump sum FOC
C Clearing of debris/ rubbish during renovation Lump sum $200.00
D Installation of bathroom and kitchen accessories only Lump sum FOC
TOTAL AMOUNT: $34,590.00
Living
3 Bedrooms
For your tiles selection, its very tight to choose from only the $2.50 range leh. my one, can choose up till, $2.90. But for your Wardrobe its considered to be very cheap. Using wat type of laminates? Then for your Plumbing items, i find that the installation charges you can still bring it down. 1 item installation at this pricing can easily set you back another 1k, if you add up all the small small items.
  • 1 month later...
yours is quite cheap to do almost for the whole house. and yeah. you're wardrobe is quite cheap. usually sliding wardrobe costs more.
