Pls Comments On My Reno Quotes
just recevied my quote from BAROQUE (my budget is $28K)
My reno is a major overhaul as it is a 25 years resale flat..
Can the experts comments on the pricing of the quote ?>>>>
Is it value for money or is there any double charging or did i miss out anything or is there cheaper alternative???
A Professional Services
1 Design & site co-ordination
2 Space planning layout plan
3 Perspective drawings on all carpentry works
4 Warranty of workmanship & after sales services for 5 years
5 Arrangement for PUB gas pipe installation
6 Consultation on selection of lights, furnitures & accessories
B Demolition Works
1 Hack off existing floor tiles & skirting @ living, dining, balcony & store room area
2 Hack off existing floor tiles & skirting @ 03 bedrooms area ( Or skirting only )
(**Valids for some units only)
3 Hack off existing floor tiles & skirting @ study room area ( Or skirting only )
4 Dismantle off existing kitchen cabinet
5 Hack off existing wall tiles @ kitchen
6 Hack off existing floor tiles @ kitchen
7 Hack off existing floor tiles @ service balcony (**Valids for some units only )
8 Hack off existing wall tiles @ both bathrooms
9 Hack off existing floor tiles @ both bathrooms
C Masonry Works
1 Supply & lay selected 600x600mm polished homogeneous floor tiles @ living, dining, balcony &
store room c/w cement screeding & skirting
2 Supply & lay German Technology laminated flooring @ 03 bedroom c/w warranty &
skirting (**Valids for some units only)
3 Supply & lay German Technology laminated flooring @ studyroom c/w warranty &
4 Supply & lay selected ceramic wall tiles @ kitchen
5 Supply & lay selected non-slip homogeneous floor tiles @ kitchen c/w cement screeding &
waterproofing
6 Supply & lay selected non-slip homogeneous floor tiles @ service balcony c/w cement
screeding & waterproofing (**Valids for some units only)
7 Supply & lay selected ceramic wall tiles @ both bathrooms
8 Supply & lay selected non-slip homogeneous floor tiles @ both bathrooms c/w cement
9 Supply & construct base for kitchen cabinet, fridge & washing machine with matching tiles
10 Haulage loading of sand, cement & materials to unit
D Plumbing Works
1 Change whole unit cold water piping to new stainless steel or copper pipe
2 Connect inlet & outlet piping for 02 nos. of wash basin
3 Connect inlet & outlet piping for kitchen sink & washing machine
4 Supply labour to install 02 nos. of basin & pedestal WC
5 Supply labour to install 02 nos. of instant heaters
6 Supply labour to install accessories @ both bathrooms
7 Supply labour to install kitchen sink, hob & hood
E Painting Works
1 Supply & apply 03 coats of Nippon paint to all internal walls & ceilings ( max.8 colours )
2 Supply & apply Nippon gloss paint to all water piping, gates, doors, door frames & sewage pipe
F Aluminium Works
1 Supply & install 02 nos. of aluminium frame bi-fold doors @ both bathroom entrance
c/w acrylic panel
G Miscellaneous
1 Supply & lay protection sheet
2 Clean up whole unit with chemical
3 Clearing off debris
H Custom Made Build-in Furniture - All laminates from Germany or Italy with solid plywood
1 Design & fabricate top & bottom kitchen cabinet in laminate finish c/w 04 sides ABS trimming
swing doors, cuttlery tray, 02 pcs of glass panels & designer handles ( max. 24ft L )
2 Supply & install stainless steel dish rack with hydralic lift-up 04 sides ABS trimming door &
glass panel ( max.3ft L )
Total Amount for A to H (Premium package) :$21,888.00
I Free Item (FOC)
1 Free solid surface worktop 12ft L worth $960 -F.O.C
2 Optional Free false ceiling or L-box at foyer, living, dining & passageway worth $800 to $1200 OR Free Delizia slimline hood & hob (KREA 90IX & DZX730) worth $878 -F.O.C( While Stock Last !!! )
3 Optional flooring @ 3 bedrooms to selected 600x600mm polished homogeneous floor tiles (**Valids for some units only) -F.O.C
4 Optional flooring @ studyroom to selected 600x600mm polished homogeneous floor tiles (**Valids for some units only) F.O.C
Additional Items
J Demolition Works
1 Dismantle existing cabinet / wardrobe 3set $200
2 Dismantle off existing doors 4nos F.O.C
3 Hack off existing sink & stove support 1set $180
4 Clearing off debris 1Lot F.O.C
Total Amount : $380
K Glass Works
1 Supply & install 10mm thick tempered glass shower screen @ common bathroom c/w
swing door & L-shaped handle 1 set $420
Total Amount : $420
L Door Works
1 Supply & install nyatoh main door c/w lock set & magnetic stopper ( non-fire rated ) 1nos $550
2 Supply & install flat nyatoh veneer doors c/w lever lock set & magnetic stopper 3nos $960
Total Amount : $1,510
M Custom Made Build-in Furniture - All laminates from Germany or Italy with solid ply wood
Living & Dining Area
1 Design & fabricate feature wall @ Tv area in laminate finish c/w glass or mirror
design & stainless steel trimming 6ft $1,080
2 Design & fabricate suspended Tv / players console in laminate finish c/w glass panels 6ft $720
Total Amount : $1,800
Master Bedroom Area
3 Supply & construct false wall for walk-in wardrobe with partition board 13.5ft $675
4 Design & fabricate full height walk-in wardrobe with polykem internal 10ft $2,000
Total Amount : $2,675
Master Bathroom Area
5 Supply & install solid surface worktop as vanity's top 2.5ft $200
6 Design & fabricate suspended vanity cabinet in laminate finish 2.5ft $300
7 Supply & install wall to wall bevelled edge mirror 2.5ft $150
Total Amount : $650
Bedroom 3 / Study Room Area
8 Design & fabricate ledge in laminate finish (2 pcs x 2ft L) 4ft $240
Total Amount : $240
N Electrical Price List
Description Unit Price Needed Amount
1 Supply & run new light points $35 31 $1,085
2 Supply & install 13amp double power point $55 13 $715
3 Supply & install 20amp power point ( Isolator ) $200 1 $200
4 Supply & install SCV point $110 1 $110
5 Supply & install telephone point $55 1 $55
6 Supply & install door bell point $35 F.O.C F.O.C
7 Supply & install 20amp power point ( Hood/ Hob ) $55 2 $110
8 Supply & install distribution board (14 way) $350 1 $350
9 Installation of hanging lights $25 1 $25
10 Installation of lights $10 30 $300
Total : $2,950
Total Package : 21888
Total Additional : 8535
Total electrical: 2950
Grand Total : $33,373
Edited by limck007
just recevied my quote from Barquore (my budget is $28K)
B Demolition Works
C Masonry Works
waterproofing
D Plumbing Works
E Painting Works
F Aluminium Works
c/w acrylic panel
G Miscellaneous
I Free Item (FOC)
Additional Items
J Demolition Works
Total Amount : $380
K Glass Works
Total Amount : $420
L Door Works
Master Bedroom Area
Total Amount : $650
Total Amount : $240
Total : $2,950
try out more contractor... see how much their can offer.. and learn more on what they can help u save
Baroque's workmanship is quite good - I checked out one of their completed project at Strathmore area. Price is a little bit steep, but not overly expensive. Go with them if you are happy with the price and design.
it says "Barquore".... spelled wrongly or different firm?
hi ,
MikaReno could offer lower price than these, please feel free to contact me at MikaReno@live.com
Thank you :)
my bad... i spelled wrongly.
its BAROQUE
do you wana try my ID? resonable and nice works too. but i really do find your electrical items to be on the high side.
Your items below, Valids for some units only, wat does it mean?
One thing about Baroque is that they don't [need to] go onsite but quote you based on your floor plan. As the result, there is some buffer built in and disclaimer (such as "valid for some units only"). The way to work is to request them to go to your new flat and explain what he is proposing. In this way he gets to see the real thing and could quote you more realistically. And more importantly, no hidden cost.
