pebblez
Mounting My Lcd Tv
I juz bot a 42" LCD TV fm Harvey. Though they hv free wall mounting, i'm juz wondering.. How do i hide the wires & cords (from the mounted TV to the TV console), without having to spend more money on doing up a feature wall? Gimme ideas, pls..
Whats the wall behind the tv console? Is it a room? and is not being blocked? If the answer is all YES, drill a hole through the mounting wall. Hide all yr connecting yr cable wires and cords behind this wall.
im planning to do this on my wall hang at master bedroom. you can do a diy u-shaped board or anything u can find and place it behind your tv, then hide your cables there. it should be flat enough so that it can fit behind the tv when mounted.
Hi, it depends on the wall. If it is not a feature or fake wall, there will be exposed wires. You can buy this long greyish tube-looking thing from Ikea. You can hide all your wires in this tube. of coz the tube will be exposed la...but better than seeing many wires hanging down. My friend used this and I thought it looked pretty okie. :)
