Hi Tiler Seng,
You inbox is full.
Can you email me your email address or contact number?
Need to discuss wall build job
Hi Slbk,
i am not sure about the new inbox... but my contact number is 82008901
RG
Edited by Tiler Seng
hi Tiler Seng
can you share your opinion how to fix a water leakage problem in the roof terrace? according to the current owner who consulted another contractor, they said to relay the tiles just ard the leakage area would be sufficient. Others don't think so and recommend to relay the whole roof terrace. What say you?
What would the est cost be with/without tiles if i have to redo the entire roof terrace?
Please pm me. many thanks
hi Tiler Seng
Hi chzmag81, should replace it all with proper water proofing too.
Tiler Seng,
Do you just do tiling work or can you do other stuff also? I suppose the tiling work would be done by you yourself and any other works if required is done by sub-con? thx.
Tiler Seng,
Hi arowana,
We insist to have our own hacker & tiler cause these are the most critical process among the whole renovation work.
The rest are all sub contracts and we are already into partnership with carpenter workshops so to provide better quality and total design control.
Hi Seng,
Do you do small jobs? I need to out source because main contractor charged me quite high.
1) Supply and fabricate concrete support with similar tiles.
2) Supply and fabricate concrete base for another side.
2) Supply and fabricate concrete washing machine and fridge base.
3) Supply labour to change few pieces of tiles (tiles supplied by owner).
Edited by Beancurd33
Hi Seng,
:) usually contractor will not get interfere with other's contractors work site,
sure end up in a mess.
Ok. I understand. Because I told my main con that his tiler guy too ex. He said I can out source if I can find a better price. Btw can you help to advise me what is the market rate or how much you usually charge?
hi
need a quote from u. hdb 4 room, tile the living room and walkway to bedroom.
also do u do laminated flooring.
please contact so i can email u floorplan
thanks
yeogi
Edited by singababa
PM sent
hi
thanks
yeogi
93806867
PM Sent!
Hi RT members! hasn't been posting any projects photo for quite awhile due to extremely busy schedule, i've been through a hard renovation since CNY and finally completed several projects and missions.
i'll post all my completed projects start from today or whenever i can for all of you out there who wish to get ideas and ideas for your on going or up coming renovation.
Project Condo: Location will not mention because case sensitive... too much trouble given by down stairs neighbour, all my workers surrender..
1st site meeting with all my sub-contractors
all windows to replace and change of use.
we asked the ex-owner to relax during site measurement, and he really rest and relax.. :D
Well site protection initially, end of the project- one wood block fallen to downstairs because of wind blow and management demanded a $500 fine, luckily downstairs owner end up helping to speak a few words for us, and the fine amount finally closed at $50 only :(
