Customised Fiberglass Planter
Hi, anyone one knows where I can customised fiberglass planter box?
I googled but to no avail.... thanks.
Looking for customised metal planter too...
OK I found it...
can share address???
POND IMAGE DESIGN & CONSTRUCTION
2 Defu Lane 10 #01-527 Singapore 539183
62842398
  • 1 month later...
62842398
When you say "custome made" I assume it is made to your specs.
If it it just square or rectangular, it will be reasonably priced.
If you are looking for special spec(your design and not standard shaped) it can cost you a bomb.
You might know that to make customised shapes, a mould need to be made from an original or if not from a plaque. This process is expensive and unless you are making it in numbers ,it is not economical.
Acetone and fibre glass sheets are not that expensive, but the labour is.
Edited by fierydragon
