U Shaped Pipe For Water Heater In Toilet?
I have a U shaped pipe I supposed is to be used for storage water heater as all the pipes are concealed already, thing is how is the ariston ti plus water heater going to fix on to the pipe, the height of the pipes are quite close to the beam on top in the toilet, will the u shape pipes be exposed after fixing the heater??
the u shape pipe will be cut into 2, 1 go to inlet and the other go to outlet of the tank.
The hot/cold piping is joined for leak detection during pressure testing. The U shaped pipe is not meant for buyer to use.
When installing the storage heater, the plumber will saw off the U, and 1 side connect to heater inlet, and 1 side connect to heater outlet.
If u dun want to install storage heater, then the U is to be left there so the cold water will run direct to the hot side of the tap.
