Bad Workmanship Granite Flooring . Please Advice ?
Hi All
I need advice for my house flooring as it done badly. Can the workers do polish or grinding to make it nicer or need to hack everything and redo ?
Please help advice. TIA.
1) Gap in between not close nicely and level not even one high and low
2) Cracks are found
3) The gap is a thick and not straight line
Edited by ninja3101
those with cracks, i dun think they can be eliminated just by polishing. you may wanna ask your contractor to redo it.
I also think the same with you. For granite impossible to clear the cracks with polish or gridding ! Either hack and redo or compensate.
yup, so if you hack one, i think may also affect the rest...this one i am not sure, probably you may wanna check with other experts / contractors.
Thanks for your advice. The contractor will hack the cracks granite and do a polish for the whole house and fill out the gaps. The renovation company is reliable after sales service.
  • 3 weeks later...
That is bad worksmanship indeed.
What type to granite you use? I mean the name of the granite?
Mine is 881, not nicely done. ...but no choice have to live with it.
